johnson counter
OP (Company: electronic srl) #7003572
someone can help me with this vhdl code for johnson counter. here is my
implementation, I'm note sure about that. The correct image is the
second one.
I have written this code in a first vhdl file, This is the Flip flop
declaration, I will use it  as a component later :
entity register_Johnson_entity is
port (D : in std_logic_vector (2 downto 0); clock : in std_logic; reset: in std_logic; q: out std_logic_vector(2 downto 0));
end register_Johnson;
architecture reg_johnson of register_Johnson_entity is
 flip_flop_async : process( clock, reset)
 begin
 if reset = '1' then
 q <= (others => "000")
 else
 q<= D;
 end if;
 end process;
 end architecture;
this is the other file that containt the main code, and where I use the
component flip flop async:
use ieee.std_logic_1164.all;
entity counter_johnson is
port (clock: in std_logic; tc: std_logic_vector(2 downto 0);
end entity;
architecture john of counter_johnson is
 signal feedback : std_logic_vector(2 downto 0);
 signal q : std_logic_vector (2 downto 0);
 component register_Johnson_entity is
end component;
-- registers update
q(1)<=q(0);
q(2)<=q(1);
q(2)<= not q(0);
-- the counter is cleared when tc =1
reset_jonshon : process(q(2),q(1))
 tc<=  q(2) and not q(1);
 if tc == '1' then
 -- reset operation
30
 q(1)=(2)=q(0)= '0';
31
 else tc == '0';
32
 end process;
33
34
-- port map operation
35
36
port map (not feedback => D ;q(0) => D; q(1) => d );
Moderator (Company: Titel) #7003716
VhdlTest V. wrote:
> This is the Flip flop declaration
Uhmmm...
This is a kind of some "dual-edge-flipflop". But only in simulation. In
real life it is a latch. And only two kind of people are using latches:
first those, who know them and their behavior very well. And second
those who don't.
You belong to the second ones.
A hint: only simulation shows some kind of interest in the sensitivity
list. The synthesizer don't. It only tells you, that the simulation
doesn't math the synthesis result.
So look at your code as if there is no sensitivity list.
Having got that right look how others describe a flipflop in VHDL. A
hint here: it has something to do with 'event or rising_edge() or
falling_edge(). The two functions are built on the' event.
Moderator (Company: Titel) #7004572
VhdlTest V. wrote:
reset_jonshon : process(q(2),q(1)) // tc is missing here, will result in weird behaviour
 tc<=  q(2) and not q(1); // assigning a bit to a vector will not work
 if tc == '1' then   // comparisons look much different, we do not 'C'
 -- reset operation
 q(1)=(2)=q(0)= '0'; // assignments do look much different
 else tc == '0';     // assignments do look much different
 end process;
Such nasty syntax errors you have throughout the whole code starting at
the very first line! Just hand your scribblescrabble over to the syntax
check to get rid of 90% of the errors. And then post it to anyone
around the world.
> -- reset operation
>  q(1)=(2)=q(0)= '0';
What means the lonely (2) here? Why do you expect such a kind of "queued
up assignement" is working in VHDL? And why not simply writing q <=
"000"?
Keep your eyes on a clean and correct sensitivity list or use VHDL-2008
and the keyword "all" instead of listing single signals.
And at all: i don't see no need for a "reset" in your picture...
My VHDL code for the pictures above would look like this:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
entity counter is
  port (clock: IN  std_logic;
        tc:    OUT std_logic_vector(2 downto 0));
end counter;
architecture john of counter is
  signal c : std_logic_vector(2 downto 0) := "000";
begin
  process begin
    wait until rising_edge (clock);
    if (c /= "100") then  c <= c(1) & c(0) & not c(2);
    else                  c <= "000";
    end if;
  end process;
  tc <= c;
end john;
Or a little bit shorter:
LIBRARY ieee;
entity counter is
end counter;
begin
  c <= c(1) & c(0) & not c(2) when rising_edge(clock);
  tc <= c;
end john;
And both of them result in the attached waveform.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
