Counter with overflow signal at 1001
OP #7001144
I am trying to make a counter that increases by one on every rising edge
if enable = 1. Additionally, if reset = 1 on a rising edge, the counter
should be reset. If the counter's current state is 9 (1001), overflow
should be one.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity BCDCounter is
port (
    clk : in std_logic;
    reset : in std_logic;
    count : out std_logic_vector(3 downto 0);
    enable : in std_logic;
    overflow : out std_logic
end BCDCounter;
architecture rtl of BCDCounter is
signal countr : unsigned(3 downto 0);
begin
    process(clk)
    begin
        if(rising_edge(clk)) then
            if enable = '1' then
                countr <= countr + 1;
                if std_logic_vector(countr) = "1001" then
                    countr <= (others => '0');
                end if;
            end if;
30
            if reset = '1' then
31
32
            end if;
33
        end if;
34
35
            overflow <= '1';
36
        else
37
            overflow <= '0';
38
        end if;
39
    end process;
40
    count <= std_logic_vector(countr);
41
end architecture rtl;
Upon running this code, I get a delayed overflow output on the switch
from 9 to 10, and I have no idea why.
ENABLED  5 -> 0101 OVERFLOW 0 OK.
ENABLED  6 -> 0110 OVERFLOW 0 OK.
ENABLED  7 -> 0111 OVERFLOW 0 OK.
ENABLED  8 -> 1000 OVERFLOW 0 OK.
ENABLED  9 -> 1001 OVERFLOW 0 FALSE!
ENABLED  0 -> 0000 OVERFLOW 1 FALSE!
RESET to ENABLED  0 -> 0000 OVERFLOW 0 OK.
DISABLED 0 -> 0000 OVERFLOW 0 OK.
ENABLED  1 -> 0001 OVERFLOW 0 OK.
DISABLED 1 -> 0001 OVERFLOW 0 OK.
Moderator (Company: Titel) #7002632
Eric J. wrote:
> I have no idea why.
Congratulations, you found the thing called "latency". This is due to
the values you are preparing in a synchronous process will happen "later
on" at the very next active clock edge.
So lets play "synthesizer": you enter the process with number 9 and find
that the overflow flag must be set.
Additionally in the very same process you find that 9 is enough and set
0 as the next value.
And of course now the overflow flag will be active together with the
counters value 0.
Have a look at the simulations waveform and think about what you see and
I wrote. Sooner or later you will get the trick.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
