4bit counter with load test bench fail
Guest #6989560
mux2to1:
library ieee;
use ieee.std_logic_1164.all;
entity mux2to1 is
  port(in1, in2, sel: in std_logic;
     output: out std_logic);
end entity;
architecture bahavioral of mux2to1 is
  begin
    process(in1, in2, sel)
      begin
        case sel is
          when '0' => output <= in1;
          when others => output <= in2;
        end case;
    end process;
end architecture;
d flip flop:
library ieee;
entity dff is
  port(d, clock, reset: in std_logic;
     q: out std_logic);
end entity;
architecture behavioral of dff is
  begin
    process(clock, reset)
      begin
        if rising_edge(clock) then
          if reset = '1' then
            q <= '0';
          else
            q <= d;
          end if;
        end if;
    end process;
end architecture;
counter:
library ieee;
entity counter is
  port(clock, reset, load, enable: in std_logic;
     d: in std_logic_vector(3 downto 0);
     a: out std_logic_vector(3 downto 0);
     carry: out std_logic);
end entity;
architecture structural of counter is
  component mux2to1
  end component;
  component dff
         q: out std_logic);
  end component;
  signal xor_out, and_out, q_out, mux_out: std_logic_vector(3 downto 0);
  begin
    block00: mux2to1 port map(in1 => xor_out(0), in2 => d(0), sel =>
load, output => mux_out(0));
    block01: mux2to1 port map(in1 => xor_out(1), in2 => d(1), sel =>
load, output => mux_out(1));
    block02: mux2to1 port map(in1 => xor_out(2), in2 => d(2), sel =>
load, output => mux_out(2));
    block03: mux2to1 port map(in1 => xor_out(3), in2 => d(3), sel =>
load, output => mux_out(3));
    block04: dff port map (d => mux_out(0), clock => clock, reset =>
reset, Q => Q_out(0));
    block05: dff port map (d => mux_out(1), clock => clock, reset =>
reset, Q => Q_out(1));
    block06: dff port map (d => mux_out(2), clock => clock, reset =>
reset, Q => Q_out(2));
    block07: dff port map (d => mux_out(3), clock => clock, reset =>
reset, Q => Q_out(3));
    xor_out(0) <= q_out(0) xor enable;
    xor_out(1) <= q_out(1) xor and_out(0);
    xor_out(2) <= q_out(2) xor and_out(1);
    xor_out(3) <= q_out(3) xor and_out(2);
    and_out(0) <= enable and q_out(0);
    and_out(1) <= and_out(0) and q_out(1);
    and_out(2) <= and_out(1) and q_out(2);
    and_out(3) <= and_out(2) and q_out(3);
    carry <= and_out(3);
    a <= q_out;
end architecture;
Above is the code for the counter. What I want is to implement a
testbench. Below is the testbench that I have written. But the testbench
is not working properly. The clock, reset, enable and load take values
properly but the d is undefined. How can I do it work?
testbench
library ieee;
entity counter_tb is
end entity;
architecture counter_tb_arch of counter_tb is
  component counter
  end component;
  signal clock_tb, reset_tb, load_tb, enable_tb: std_logic;
  signal d_tb: std_logic_vector(3 downto 0);
  signal a_tb: std_logic_vector(3 downto 0);
  signal carry_tb: std_logic;
  begin
    dut: counter port map(clock => clock_tb,
                reset => reset_tb,
                load => load_tb,
                enable => enable_tb,
                d => d_tb,
                a => a_tb,
                carry => carry_tb);
    reset_stim: process
      begin
        reset_tb <= '1'; wait for 20 ns;
        reset_tb <= '0'; wait;
    end process;
    clock_stim: process
      begin
        clock_tb <= '0'; wait for 20 ns;
        clock_tb <= '1'; wait for 20 ns;
    end process;
    enable_stim: process
      begin
        enable_tb <= '0'; wait for 50 ns;
        enable_tb <= '1'; wait;
    end process;
    load_stim: process
      begin
        load_tb <= '0'; wait;
    end process;
end architecture;
Guest #6989625
you have processes, that assign defined values to clock_tb, reset_tb,
enable_tb and load_tb. But you do not assign anything to d_tb, which is
an input of your counter.
assign a defined signal to d_tb.
Guest #6989888
My updated testbench is below. I initialize the d_tb and when the
load_tb = 0 the counter starts from 0. When load_tb = 1 I made it jump
to 0101 and counts from there. How can I make it jump again into a new
value. I put a new value to d_tb as you can see in load_stim process but
the counter does not jump to the new value, rather continues from the
last value. Thanks for responses and I am new to hdl programming, trying
to understanding by myself, as I came from a programmer background
library ieee;
end entity;
  component counter
  end component;
  signal d_tb: std_logic_vector(3 downto 0) := "0000";
  begin
                reset => reset_tb,
                load => load_tb,
                d => d_tb,
                a => a_tb,
                carry => carry_tb);
    reset_stim: process
      begin
        reset_tb <= '1'; wait for 21 ns;
    end process;
    clock_stim: process
      begin
    end process;
      begin
    end process;
    load_stim: process
      begin
        load_tb <= '0'; wait for 200 ns;
        load_tb <= '1'; d_tb <= "0101"; wait for 20 ns; d_tb <= "0101";
wait for 20 ns;
    end process;
end architecture;
Guest #6989995
No, your value is 0101. All the time.
You can write the process as below:
load_stim: process
      begin
        load_tb <= '0';
    wait for 220 ns;
        load_tb <= '1';
    d_tb <= "1001";
    wait for 40 ns;
    load_tb <= '0';
    wait for 200 ns;
    load_tb <= '1';
    d_tb <= "0101";
    wait for 40 ns;
    load_tb <= '0';
    wait;
    end process;
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
