Binary counter
Guest #6988594
Hello I would love your help
I designed a simple binary counter,
though if I do not put the single Q in the sensitivity list. The counter
updates falling_edge Why is that?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.all;
use IEEE.STD_LOGIC_UNSIGNED.all;
entity Binary_Counter is
--generic( n :   positive:=24);
    Port (
           Clk : in STD_LOGIC;
           -- the LTF(n) signal
           Up_Down : in STD_LOGIC;
           -- Up_Down ='1'  the counter counts up
           -- Up_Down ='0'  the counter counts down
           T_Gate : in STD_LOGIC;
           -- Enable count
           O : in integer range 0 to 10:=2;
           -- The number of times the counter works
           ResetS : in STD_LOGIC;
           -- Asynchronously reset
           Pe : in STD_LOGIC;
           -- Asynchronously loads data on the Preset Inputs.
           Pi : in STD_LOGIC_VECTOR(23 downto 0);
           --Data on these inputs is loaded into the counter when PE is
taken high.
           Q_Out : out STD_LOGIC_VECTOR(23 downto 0);
           -- Binary data is present outputs
           Carry_Out : out STD_LOGIC);
           --used to indicate terminal count.
end Binary_Counter;
architecture Behavioral of Binary_Counter is
signal Q : STD_LOGIC_VECTOR(23 downto 0):=(others=>'0');
begin
process(Clk,ResetS,Pe,T_Gate,Up_Down)
variable CountQ : integer range 0 to 10:=O;
begin
if( ResetS = '1') then Q<=(others=>'0');
            elsif(CountQ /=0 and T_Gate='1') then
             if(rising_edge(clk)) then
                if( pe='1' ) then Q<= pi;
                        elsif(Up_Down='1') then
                                if(Q=x"111111") then
                                    Carry_Out<='1';
                                    Q<=x"000000";
                                else
                                    Q<=Q+1;
                                end if;
                         else
                            if(Q=x"000000") then
                                Carry_Out<='1';
                                Q<=x"111111";
                            else
                                Q<=Q-1;
                            end if;
                 end if;
             end if;
end if;
Q_Out<=Q;
end process;
end Behavioral;
Guest #6988625
At first some basics hints:
thats outdated and should never be used.
Next, write a clean clocked process. Only reset should be outside of
rising_edge.
Guest #6988637
Oh well ... where to start?
--- 1. ---
Do not use those! But use instead
use ieee.numeric_std.all;
--- 2. ---
Try to use only std_logic and std_logic_vectors for ports.
--- 3. ---
Try to avoid variables if you do not know how they work.
And the code suggests you do not know that.
--- 4. ---
CountQ is only assigned at the start of the process but never changed.
So there is no need to use it at all.
--- 5. ---
You can write it that way, but you only need the asynchronous signals +
clock. So O, T_Gate, ResetS and Clk would be sufficient.
--- 6. ---
I do not understand the function of O.
--- 7. ---
Try to use "speaking Names"
Pe, Pi say nothing to me, you could name them
Preset_load and Preset_value or the like.
--- 8. ---
A very simmilar question (same counter) was asked in the german section
of the forum. Look here:
Beitrag "VHDL Anfänger braucht Unterstützung (keine Lösung)"
Guest #6988649
--- 9. ---
Carry_Out is undefinded till it is set to '1'. This is an error!
--- 10. ---
Try to format your code for easy reding + understanding.
--- 11. ---
To your initial question:
daniel wrote:
> The counter updates falling_edge Why is that?
This is because you have written (shorted):
process (Clk,ResetS,Pe,T_Gate,Up_Down)
begin
  if rising_edge(clk) then
    if Up_Down='1' then
      if Q = x"111111" then
        Carry_Out <= '1';
        Q <= x"000000";
      else
        Q <= Q + 1;
      end if;
    else
      if Q = x"000000" then
        Carry_Out <= '1';
        Q <= x"111111";
      else
        Q <= Q - 1;
      end if;
    end if;
  end if;
  Q_Out <= Q;
end process;
So Q updates with every rising_edge of the clock. But the process itself
is restarted with every action on all of these signals
(Clk,ResetS,Pe,T_Gate,Up_Down), so it is restarted on the falling_edge
of the clock, too. And because Q was updated on the rising_edge, with
Q_Out gets the new value with the next process run which is with the
next falling_edge.
To avoid this you should write
Q_Out <= Q;
outside the process or write it inside the
end if;
part. But: If you write it in the if rising_edge(clk) then ... part, you
get 1 clock cycle latency. So you may want to write it outside the
process.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
