Accessing dut variables in testbench : VHDL
OP (Company: Self) #6965994
Hey gals and guys,
So all I want is to access the "sw" from testbench and check it for a
certain value. I do it regularly in Verilog, but this VHDL is a little
harsh on me. Just see the "assert_test" process below. There in second
assert expression I tried to do that, but still no success. Any
soloutions to this situations?
Entity
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- FPGA projects using Verilog code VHDL code
-- fpga4student.com: FPGA projects, Verilog projects, VHDL projects
-- VHDL project: VHDL code for counters with testbench
-- VHDL project: VHDL code for up counter
entity UP_COUNTER is
    Port ( clk: in std_logic; -- clock input
           reset: in std_logic; -- reset input
           counter: out std_logic_vector(3 downto 0) -- output 4-bit counter
end UP_COUNTER;
architecture Behavioral of UP_COUNTER is
signal counter_up: std_logic_vector(3 downto 0);
signal sw: std_logic;
begin
-- up counter
process(clk)
begin
if(rising_edge(clk)) then
    if(reset='1') then
         counter_up <= x"0";
         sw <= '0';
    else
        counter_up <= counter_up + x"1";
        sw <= '1';
    end if;
30
 end if;
31
end process;
32
 counter <= counter_up;
33
34
end Behavioral;
Testbench
-- Code your testbench here
-- or browse Examples
library IEEE;
-- VHDL project: Testbench VHDL code for up counter
entity tb_counters is
end tb_counters;
architecture Behavioral of tb_counters is
component UP_COUNTER
end component;
signal reset,clk, en: std_logic;
signal counter:std_logic_vector(3 downto 0);
begin
dut: UP_COUNTER port map (clk => clk, reset=>reset, counter => counter);
   -- Clock process definitions
clock_process :process
begin
     clk <= '0';
     en  <= '0';
     wait for 10 ns;
30
     clk <= '1';
31
     en  <= '1';
32
     wait for 10 ns;
33
end process;
34
35
36
-- Stimulus process
37
stim_proc: process
38
begin
39
   -- hold reset state for 100 ns.
40
    reset <= '1';
41
    wait for 20 ns;
42
    reset <= '0';
43
   wait;
44
end process;
45
46
-- assertion test
47
assert_test: process
48
begin
49
    wait for 21 ns;
50
    if(en = '1') then assert reset /= '1' report "Assertion violation." severity error;end if;
51
    if(en = '1') then assert << signal dut.sw : std_logic >> = '1' report "Second Assertion violation." severity error;end if;
52
    wait;
53
end process;
54
55
56
end Behavioral;
OP (Company: Self) #6966029
Lothar M. wrote:
> What do you want to do? What should happen? And what happens instead?
I want to evaluate that assert expression, and when that variable(SW)
doesn't have the required value(as in assertion) then it should throw an
error. At the moment, although code is not failing, but this expression
is also not getting evaluated property, or at all.
Is this right way to check value of SW variable?
Moderator (Company: Titel) #6966087
> SW variable?
SW ist not a variable. It is a signal. There a huge difference
between...
See it that way: a testbench is just a "normal" VHDL entity without any
ports to somewhere. But in this VHDL module you instantiate components,
maybe one, maybe several. Those components themself may have other
components in their entity, and so forth.
And because a testbench is a VHDL module like any other you cannot
access internal signals just with a '.'
The usual way is to pass signals from the component to the "upper level"
entity is by means of the port list like the counter, reset and clk...
#6966701
works ony with VHDL2008 setting in your simulator - for examples see:
https://www.doulos.com/knowhow/vhdl/vhdl-2008-easier-to-use/
(scroll down)
another example:
https://support.xilinx.com/s/question/0D52E00006hpXtRSAU/correct-syntax-to-reference-a-hierarchical-signal-in-a-vhdl-2008-testbench?language=en_US
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
