Forum: FPGA, VHDL & Verilog Adaptive huffman algorithm in vhdl
von Robin (Guest)
I have a task to implement adaptive huffman algorithm in vhdl.
In the program i have to deal with some registers including one for the
output of variable bit length. Some times the output will be in 128
bits. Some other time my output length will be 60 bits. Sometimes 200
bits.. So on. The output bit length will depend on the input symbols and
its repeated occurance. So there are so many possible bit lengths for my
output. In that case how can i write my output register with variable
bit length. Like can i write it as
Output : encoded_out( i down to 0);
i can be optained from program.. Like that.. Is this possible????
von Duke Scarring (Guest)
You just need an additional register for the valid length...
What happens when you try it?
Of course you cannot change the "length" of a output vector dynamically,
because simply imagine those outputs bits would be connectoed to FPGA
pins. Should the FPGA dynamically shrink and expand as change a digital
value?
Ok, having got that the reslut is fairly easy: as port you use the
broadest result-vector you will ever need (here it was 200 bits) and
then you add a second vector (let it be the i-vector) that tells how
much (or what part) of that result-vector is the valid result.
