high impedance use others
OP (Company: NON) #6921563
Hello everyone, I would like our  help - I try to put a high impedance
on the single using the "others" command but it does not work, from what
I understand the single should be set as inout.
But I defined the single as an "insysteam" single.
Moderator (Company: Titel) #6921594
What "does not work"? How do you see that it "does not work"?
Which part of the toolchain gives what error?
All in all: where did you find that coding style with an 'event buried
deeply inside combinatorial logic? Did you check that against the
synthesizers user guide of your specific toolchain?
BTW: Pls attach code as code and NOT as a picture!!
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
