as8510 arduino library request
OP (Company: vdl bus&coach) #6889593
Hello,
I'm looking for the arduino library for the AS8510 current sensor of
AMS. They have created a arduino shield but the library is not readily
available. I sent a request for this library but I'm not sure if they
gonna respond.
Any hints or a downloadlink is highly appreciated.
#6894608
Hi....You've presumably currently discovered that some Arduino portrays
expect you to introduce libraries. What may not be so clear is that a
few libraries have conditions on different libraries. So you really want
to introduce both the library your sketch utilizes just as the libraries
those libraries use, etc.
At the point when everything is done a good job for the library
creators, this is totally dealt with naturally by the Arduino IDE.
Lamentably, the creator of the library you're utilizing has not
accommodated that comfort, so somewhat more exertion is required on your
part. However, it's simple enough.
OP (Company: vdl bus&coach) #6908323
Thank you for replying but I have no idea what you just said. Does
somebody has this library ? I didnt receive an answer of the AMS support
and via arduino IDE search i dont find the library neither.
Start a new thread
