Does anybody know this microcontroller ?
OP #6873903
• ▲ useful
▼ not useful
Hello guys
I'm in front of this µcontroller named : 2622A44FAV.
No information available on Google.
This µcontroller is seated in a invacare wheelchair ECU (ref DK-PMB21).
The ECU is build by the Dynamic compagny located in New zeland. It's
also the brand I found on the µcontroller.
Do you know more from this part ?
Should I consider it's a part build exclusively for Dynamic ?
Or (my assumption) it's a regular µcontroller with only a dynamic
labelling ?
In this case what method should I use to find the real hidden part
number ?
Thks for your support.
vincent
Guest #6874133
• ▲ useful
▼ not useful
What is the marking on the SO8 component on the right ?
What dies your chip do, control 2 BLDC motors with sensors ?
May it be sn FPGA with serial EEPROM and the black epoxy dot on the left
is the uC ?
There is no way to repair. If it is a programmed uC, you do not have the
program. And probably it is not defective.
Guest #6874436
• ▲ useful
▼ not useful
Thks for your replies
The part on the right is a 16K EEPROM (24LC16B)
I have absolutly no clue...what this chip could be.
This ECU manages the jostick, the motors and the back recline motor, the
lights and the battery charging. That's a lot ...
I start to retro-engineer the ECU to take over the H-bridge (at least)
and maybe some other functions for another purpose.
This can be a cheap way to handle the 70 amps motors.
H-bridge command circuitry is quite easy to find with the 4x2 MOSFET + 4
H-bridge drivers (IR21844).
Here the full view of the (nice and well build) PCB.
Vincent
Guest #6874456
• ▲ useful
▼ not useful
> number ?
The simple but stony path is to reconstruct the schematic (at first the
GND and VCC and Clock and reset connections) and search in the internet
for a matching chip.
And when you found a pincompatible chip, you are not at the end of your
journey, but rather just one step away from the starting line. To make
your own firmware, you need a lot more of effort. And do not believe,
that a firmware on a chip labeled on customers request is readable.
Particularly if the chip has a damage.
Good luck.
W.S.
Guest #6875105
• ▲ useful
▼ not useful
W.S. wrote:
>> number ?
> Good luck.
> W.S.
Yeap
That's why a plan to graft a ESP32 on top of that and hook up all
connection a need.
Thks
Guest #6875249
• ▲ useful
▼ not useful
This EEPROM is too small to hold the complete firmware for a FPGA, so it
probably only stores user parameters.
Not in this circuit. This is way to tiny to handle 70Amps. You should
provide at least 5 times the current the motors draw to be on the safe
side - e.g. 3 IRFB3205 in parallel for each MOSFet.
Guest #6875624
• ▲ useful
▼ not useful
Yes this is also my point of view
I wrote it unclear. The motors are given for 70 amps but it's the peak
current.
The ECU can provide 18A nominal, 60A during < 60sec and additional 15A <
10sec.
I'll look closely to the MOSFET but ECU & motors are build in so they
should works properly together.
Attached some pictures
Start a new thread
