connected DIN MIDI Out cable disturbs encoder
Guest #6872015
Hey,
i am currently working on a MIDI related project utilizing a STM32F103
and a Hex Buffer (74HC365). I have the following problem: reading the
encoder works fine (handled via interrupts) until i connect a midi cable
to the midi out port, then the readings of the encoder get sloppy. I
think it might be some interference problem, since everything works
fine, when i attach a serial adapter instead of a midi cable to the
output.
I attached a simplified schematic of my curcuit.
Do you have any idea what could cause the problem and how i can protect
my circuit?
Guest #6872030
The internal Pull-Up resistors habe about 50kΩ, so they are very weak.
The lines can easily receive radio signals.
You need stronger Pull-Up resistors, for example 2,2kΩ. Also your
capacitors are on the wrong side. The encoder contacts will shorten the
capacitors, which leads to short pulses of very high current.
Better:
        2.2kΩ
3,3V o--[===]--+    100Ω
µC o-----------+---[===]---o Encoder contact
GND o----------+-----------o
Guest #6872034
i just figured it i make the ground connection closer to the power
supply the problems disappears. any idea what could be happening there?
Guest #6872055
Search for en explanation of "ground loop" and why GND connections shall
form a star to work properly. The web is full of related documentation.
Guest #6872056
Hey Stefanus!
Thanks a lot. your circuit seems to work much better - meaning without
any problems! i placed some pullup resistors, and you are right: the
capacitors should be placed behing the 100 Ohm resistors.
Guest #6872068
im still working on a breadboard to test out all the components. so
there is not really any propper GND layout yet. but it will follow your
advices when i create the pcb layout.
Guest #6872072
The main related pyhsical effect is:
Every line has an inductance and a capacitance. So every line is more or
less an antenna (more for higher frequencies) which sends and receives
radio signals.
Also the purpose of GND is a unique common potential that all signals
are derived from. If you have a few centimeters of GND wire, it will
have already more than 0 Ohm. As higher the frequency, as higher the
resistance. And resistance together with currency produces a voltage
drop.
So GND is not the same GND everywhere, and that arises lots of different
problems.
Guest #6872079
Breadboard make it even worse because the usually have contacts and
cables made from iron which has a significantly higher resistance than
copper.
Consider to solder the power supply wires and plug only the signal wires
which are less critical.
Start a new thread
