How to add two signals of type std_logic
OP (Company: DefineView Consulting) #6841914
Hello,
I understand that you cannot add two std_logic_vector types because a
std_logic_vector does not have a numeric value. You have to convert
std_logic_vector to signed/unsigned; do the math operation and convert
result back to std_logic_vector.
But how do you add two signals of type std_logic? A std_logic type
cannot be converted to signed/unsigned type because that requires an
array type.
I tried the following
signal D, E, F : std_logic;
signal G : std_logic_vector (0 to 0);
begin
  Monitor: process is
  begin
   D <= '1'; E <= '0';
   --F <= D + E; --Compile Error - D and E are not numeric values.
   --F <= unsigned(D); --Compile Error - D must be an array type.
   --F <= unsigned(G); --NO
   --G <= '1'; --NO
Any suggestions?
Thanks very much.
Moderator (Company: Titel) #6841939
Ashok M. wrote:
> A std_logic type cannot be converted to signed/unsigned type because
> that requires an array type.
Why digging in the mud and defining own "rules"?
The definition of a signed/unsigned ist very similar to that of a
std_logic_vector, you can check that out the free available code of
those packages:
https://www.csee.umbc.edu/portal/help/VHDL/packages/numeric_std.vhd
Package numeric_std is
-- Numeric array type definitions
type UNSIGNED is array ( NATURAL range <> ) of STD_LOGIC;
type SIGNED is array ( NATURAL range <> ) of STD_LOGIC;
And:
https://www.csee.umbc.edu/portal/help/VHDL/packages/std_logic_1164.vhd
-- unconstrained array of std_logic for use in declaring signal arrays
TYPE std_logic_vector IS ARRAY ( NATURAL RANGE <>) OF std_logic;
> Any suggestions?
VHDL does not give room to laziness and implicity. Everything thats
written must be written down explicitly.
Simply use the numeric_std package to cayst between std_logic_vector and
signed/unsinged. And use the vesy same package to convert from integer
to signed/unsinged and vice versa:
http://www.lothar-miller.de/s9y/categories/16-Numeric_Std
The same picture also exists in english mutations.
You are taking all tricky steps at once: 1. a one element array 2. with
very strange bit order...
Guest #6842047
Sure! But what do you expect? D and E are one Bit each and F is also
only one Bit. So how should addition work? What is '1' + '1'? If you say
2 this is "10" and will not fit in the single Bit of F.
Ashok M. wrote:
> G <= '1'; --NO
G <= "1";
Guest #6842062
But ... it can be done, add two std_logic and get one std_logic_vector(1
downto 0).
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity tb_add_std_logic is
end tb_add_std_logic;
architecture tb of tb_add_std_logic is
constant dummy : unsigned(1 downto 0):="00";
signal D : std_logic:='0';
signal E : std_logic:='0';
signal F : std_logic_vector(1 downto 0):="00";
begin
D <= not D after 10 ns;
E <= not E after 13 ns;
F <= std_logic_vector(dummy + (""&D) + (""&E));
end;
OP (Company: DefineView Consulting) #6842780
Thanks very much for the solution. It worked. I come from Verilog
background, and it is straight forward (loosely typed language) to add
two single bits and assign result to a single bit (discarding the msb).
In line with your solution, I tried the following and that worked as
well.
  variable G : std_logic_vector (1 downto 0);
  variable D, E : std_logic;
  variable uS1 : unsigned (1 downto 0);
  uS1 := unsigned'('0' & D) + unsigned'('0' & E);
  G := std_logic_vector(uS1);
Thanks.
> downto 0).
library ieee;
> begin
> end;
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
