10gbase kr with sfp 10gbase t sfp+ pluggable?
#6841715
teasnakl wrote:
> hi is it possible to connect a 10 gbase  kr phy via 10 gbase t sfp+
> pluggable
10GBASE-T and SFP+ are two different things.
10GBASE-T is the standard for transmitting 10 GBit Ethernet over 4 pairs
of twisted pair copper.
SFP+ is the socket you can plug in 10 GBit fiber modules or direct
attach cables.
I guess with "10 gbase t sfp+ pluggable" you mean a SFP+ direct attach
cable, correct?
> pluggable to another 10gbase t sfp+  pluggable in a pc which supports
> different protocols (i hope also kr) ?
> or should i use a 10gbase-cu sfp+ cable?
10GBASE-KR is a standard explicitly for backplanes. You can't directly
connect it to any of the other 10 Gbit Ethernet standards. So if you
have a PHY for 10GBASE-KR, then you need another 10GBASE-KR PHY on the
other side of the connection. If you want to connect it to a PC, you'd
need some media converter that has a 10GBASE-KR connection on one side
and for example a SFP+ slot on the other side.
Guest #6841720
in my opinion this is not true.
10GBASE-KR is for backplane application and has improvements on signal
quality and an optional forward error correction. But everything is
automatically handled with auto-negotation. If the phy does additionally
support you can connect it directly to a SFP+ module via the so called
SFI interface.
So, what phy are you using? this will help a lot to answer your
question.
Guest #6843933
> question.
vsc8489
Datasheet explain modes:
1111: 10BASE-T (not supported)
1110: 100BASE-TX (not supported)
1101: 1000BASE-KX
1100: 1000BASE-T (not supported)
1011: 10GBASE-KR
1010: 10GBASE-KX4 (not supported)
1001: 10GBASE-T (not supported)
1000: 10GBASE-LRM
0111: 10GBASE-SR
0110: 10GBASE-LR
0101: 10GBASE-ER
0100: 10GBASE-LX-4
0011: 10GBASE-SW
0010: 10GBASE-LW
0001: 10GBASE-EW
0000: Reserved
> attach cables.
yes and 10 GBase T for "standard" RJ45 Twisted Pair
thank you
yes this is what i suspected, actually the pc-card maybe supports the
KR-protocol,  but even the ethtool doesnt say it xD
For a first test i could change my phy to SR mode, which is supported by
my pc-card.
I dont need SFP+ Fiber dont I? I can do it with SFP+ 10GBase T?
I will check it :)
Guest #6843966
> I will check it :)
PHY( SR Mode) -> SFP+ for 10GBase T-> SFP+ for 10GBase T-> Ethernet Card
I dont really know if this makes sense.
Guest #6847919
TO = thread opener ;-)
the interface between phy and sfp+ is specified and called SFI. Any SFP+
module has absolutely the same electrical interface standard. So in
general for the phy it isn't important what type connected: 10GBASE-SR,
10GBASE-ER, 10GBASE-LR, 10GBASE-T, etc.
So connection between phy and SFP+ is fine.
Next step:
10GBASE-T at your hardware and 10GBASE-T at your network adapter in your
PC. Between them there is the electrical interface standard with a PAM
(pulse amplitude coding). Buter after the SFP+ there is the SFI
interface with NRZ coding again.
You can believe it or not, but it will work. And when you don't believe
then take the datasheet, literate especially you should read the IEEE
802.3 specification where everything is described in detail.
Good luck
Guest #6848381
Hi tja,
I still don't understand the compability yet, but SFI might be a good
solution!
Thank you :D
I will/need-to check out SFI,SerDes,IEEE and so on!
Until then i ask myself:
E.g. 10GBase-T descirbes twisted pair cable. When plugging a SFP+
inside, the SFI should transform the twisted pair signals to SFP+... and
e.g. 10GBase CX4 also to SFP+.
I mean:
phy(some ethernet standard)->sfi->sfp+-> cable
I found these books which maybe tells something about it. Hadn't time to
read into it now.
https://www.google.de/books/edition/High_Speed_Serdes_Devices_and_Applicatio/Cx3r0H-4AhEC?hl=de&gbpv=1&dq=serdes+frame+interface&pg=PA204&printsec=frontcover
https://www.google.de/books/edition/Network_Infrastructure_and_Architecture/YVQID9pY1rIC?hl=de&gbpv=1&dq=serdes+frame+interface&pg=PA250&printsec=frontcover
Guest #6852048
Thank you,
I began to check the IEEE standards. Starting with PMA ...
I just got maybe 10% of understanding.
It looks like the PMA is directly connected to the Pins. E.g. at 10GBase
T the 4 differential pairs...
I will check more :D
Guest #6855362
I am still not 100 % sure. If my PHY is only able to do Clause 73
Auto-Negotiation. Because if the SFP+ does some translation but has no
intelligence two systems won't fit like Backplane Ethernet (KR,Kr and so
on, but no 10GBaseT)  and my 10GbE Ethernet NIC(no KR and stuff my PHY
supports.)
... But a 16 ms signal-burst-signal should be sent be each of them
right?
Check this out, in Clause 73 it says:
>"While implementation of Auto-Negotiation is mandatory for Backplane >Ethernet
PHYs, the use of
>Auto-Negotiation is optional. Parallel detection shall be provided for >legacy
devices that do not support
>Auto-Negotiation."
And whatever that means:
>"If Clause 37 Auto-Negotiation is performed after Clause 73 >Auto->Negotiation,
then the
>advertised abilities used in the Clause 37 Auto-Negotiation shall match >those
>Clause 73 Auto-Negotiation."
Guest #6863183
Interesting:
I checked my PHY design and saw that there is only one RX and TX pair
connected to the SFP+ port!
I think all SFP+ have only one RX and TX pair.
E.g. the 10GBase T Standard wants 2 pairs of RX and TX!
So How is that working?
I think the data are transformed from 8 to 4 lanes at the SFP+.
So if the phy understands this one pair protocol it will be fine.
Is this the solution of my question?
So I think the 4 lanes of my PHY are translated into 8 lanes of my
RJ45-cable and than back at the SFP+ plug in my NIC.
So my NIC should understand my PHY.
If I would use a DAC the 4 wires would attache directly to the pcb.
what do you think?
Guest #6863198
ah i didnt thought about why my phy only understand 4 pair ethernet...
but it must have something to do with the standards. every standard uses
the same PMA with only 4 lanes. So 10 GBase or KX4 has 8 lanes. The phy
dont support it. My NIC supports it... I dont know how!
Guest #7045779
There is some misunderstanding here. 10GBASE-T uses all 4 pairs in both
directions. The necessary signal processing is complicated and power
hungry.
An SFP+ module for 10GBASE-T is complicated internally.
10GBASE-T is very different from all other 10G ethernet.
Start a new thread
