Siemens TBB206G CMOS PLL synthesizer integrated circuit
Guest #6808377
Hi there,
I have a problem with a Siemens TBB206G CMOS PLL EEPROM file on my
Sennheiser Wireless receiver (see attachted file). I want to change the
frequency in this EEPROM file as there are 16 frequency in this file
(668200 MHz, 668700 MHz, 669600 MHz, 670200 MHz, ...., 673850 MHz) to
another frequency in this range (668200 MHz to 674000 MHz). for example:
668200 MHz changed to 668400 MHz
668700 MHz changed to 668900 MHz
673850 MHz changed to 674000 MHz
Thanks,
Dang Huynh
Guest #6809290
Hi 0ri0n,
My target is changing the frequency in the EEPROM file which is
controlled by TBB206G. I want to find the total division factor (N, A,
R) as the contain of EEPROM file look like:
668200  <-->  2A3ADE
668700  <-->  0E3AEE
669600  <-->  423AFE
671650  <-->  5C3B2E
672450  <-->  7C3B3E
673450  <-->  443B5E
673850  <-->  143B6E
668200 (DEC) --> 2A 3A DE (HEX)
So if i want to changing 668200 (2A3ADE) to 668400 (......?)
i need to know what is the exactly of total division factor (N, A, R)
Thanks
Guest #6810290
Min. PLL step size: 5 kHz
VCO Prescaler (P/P+1): 128/129
Ref. Frequency: Fr = 4000 kHz
Ref. Divider: R = 4000 kHz / 5 kHz = 800 (constant value, not saved in
EEPROM)
First IF Frequency: Fi = 65750 kHz
The VCO oscillates 65750 kHz below the receiving frequency. With the
TBB206 PLL chip the total VCO division factor is M = N * P + A. Divider
A is always smaller than Divider N. Divider P (prescaler factor) is 128.
Example (Channel 1):
F = 668200 kHz (starting at offset #40 in EEPROM)
N/A divider = #2A 3A DE (starting at offset #140 in EEPROM)
According to the TBB206 datasheet, the N/A divider needs 22 bits. The
last 3 bits contain the target address. In dual modulus mode this bits
have to be 111.
N/A divider in binary: 0010 1010 0011 1010 1101 1110.
First and last bit is always 0. Bits 2...8 contain the value of divider
A and bits 9...23 that of divider N.
Divider A = 42
Divider N = 941
Total division factor: M = N * P + A = 941 * 128 + 42 = 120490
VCO frequency: Fvco = M * 5 kHz = 602450 kHz
Receiving frequency: F = Fvco + Fi = 602450 kHz + 65750 kHz = 668200 kHz
For moving channel 1 to a frequency of 668400 kHz you could keep divider
N at 941 and increase divider A to 82.
#6810727
0ri0n was posted
> have to be 111.
> Divider A = 42
> Divider N = 941
Hi 0ri0n,
I would like to thank you so much! It is work perfectly. I have changed
the frequency successfully.
Regards,
Dang Huynh
Start a new thread
