Stepdowns in parallel
OP #6805093
Hi
I have read in some forums that you should not close stepdowns in
parallel without certain safeguards. In my project I have a Raspberry Pi
that controls servomotors. These pull so much that a 9A stepdown is not
enough. Now I plan to connect several small stepdowns (XL 4015) in
parallel to my LI ION battery block with BMS. Each stepdown then
supplies 3 servomotors. I have a total of 18 servos, so 6 stepdowns.
Is that possible without causing any damage or the like?
I am very happy to receive an answer
Kind regards Max
Moderator (Company: Titel) #6805179
No, because you do not use them in parallel at the output side. Just
beware that you must connect all of them GND together.
> that a 9A stepdown is not enough.
If these are the usual 9 Chinese Ampere, then divide this value by 5 to
get Real World Amperes.
Guest #6805182
> you should not close stepdowns in parallel without certain safeguards.
That's about the outputs.  In your case only the inputs are connected
which is fine.
Start a new thread
