How to use PWM
OP #6773090
I am using an Arduino Uno, Stone TFT LCD, and F5LED and I want the LED
to get brighter and brighter as the number increases when I tap the "+"
on the screen and conversely get dimmer and dimmer. I've tried using PWM
but it doesn't seem to work. How do I change my code?
Guest #6773131
Delete everything, learn some basic programming techniques, start over.
PWM_DUTY is not changed, not used, and the analogWrites receive only
values from 0..255, not 0..1023.
#6774560
Pulse Width Modulation (PWM) is a fancy term for describing a type of
digital signal. Pulse width modulation is used in a variety of
applications including sophisticated control circuitry. A common way we
use them here at SparkFun is to control dimming of RGB LEDs or to
control the direction of a servo.
Start a new thread
