Synchronous two PWM signals generator
OP #6765552
Hi to all,
I try to generate two synchronous PWM signals however I missing
something. I'll be grateful if you could assist me.
1. Two signals should start at the same time.
2. When PWM_1 is rising edge the PWM_2 should be start either.
3. PWM_1 is 1us period , 0.5 uS high ('1') and 0.5 uS low ('0'). 50%
Duty cycle.
4. PWM_2 is 1uS period , 0.3uS high ('1') and 0.7 us low ('0'). 30% Duty
cycle.
Code and simulation attached .
Simulation :
CODE :
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY clk1 IS
PORT (
clk : IN STD_LOGIC;
reset : IN STD_LOGIC;
clk_out : OUT STD_LOGIC;
pwm_1 : OUT STD_LOGIC;
pwm_2 : OUT STD_LOGIC
END clk1;
ARCHITECTURE Behavioral OF clk1 IS
SIGNAL temporal_1 : STD_LOGIC;
SIGNAL temporal_2 : STD_LOGIC;
SIGNAL temporal_4 : STD_LOGIC;
SIGNAL counter_1 : INTEGER RANGE 0 TO 4 := 0;--780 original
SIGNAL counter_2 : INTEGER RANGE 0 TO 4 := 0;--780 original
SIGNAL counter_3 : INTEGER RANGE 0 TO 4 := 0;--780 original
SIGNAL counter_4 : INTEGER RANGE 0 TO 4 := 0;--780 original
BEGIN
freq_divider_1 : PROCESS (reset, clk)
BEGIN
IF rising_edge(clk) THEN
counter_3 <=counter_3+1;
--counter_4 <=counter_3+1;
END IF;
30
31
IF (reset = '1') THEN
32
temporal_1 <= '0';
33
counter_1 <= 0;
34
ELSIF rising_edge(clk) THEN
35
36
IF (counter_1 = 4) THEN
37
38
temporal_1 <= NOT(temporal_1);
39
40
counter_1 <= 0;
41
ELSE
42
counter_1 <= counter_1 + 1;
43
END IF;
44
45
END IF;
46
47
48
49
temporal_2 <= '0';
50
counter_2 <= 0;
51
52
53
IF (counter_2 = 3) THEN
54
55
temporal_2 <= NOT(temporal_2);
56
counter_2 <= 0;
57
ELSE
58
counter_2 <= counter_2 + 1;
59
IF counter_2 = 2 THEN
60
temporal_2 <= '0';
61
ELSE
62
temporal_2 <=temporal_2;
63
END IF;
64
END IF;
65
66
END IF;
67
68
END PROCESS;
69
70
clk_out <= temporal_1;
71
pwm_1 <= temporal_1;
72
pwm_2 <= temporal_2;
73
74
END Behavioral;
Thanks.
Stas.
Moderator (Company: Titel) #6765644
The forum sw has some problems with correct rendering since the last
update...
But to cut down your code it looks like that:
BEGIN
END IF;
END IF;
END IF;
END PROCESS;
Where did you find that fairless amazing coding style with several
"subprocesses" in one process?
Are you sure, that your synthesizer is able to generate hardware out of
this?
> however I missing something.
I would implement 1 counter steadily counting from 0 to 9. One step each
100ns. Then I would set both of the PWM outputs high with counter = 0,
and I would reset one PWM output with counter = 4 and the second PWM
output with counter = 6. Sounds kind of easy...
OP #6771032
Thank you Lothar.
It has been synthesized. I tried what you had offered and the  PWM 2
doesn't starts synchronous with PWM 1, it synchronous for the first time
only.
I changed my code at all. Similar to state machine.
Thank you a lot.
My regards,
Stas.
Moderator (Company: Titel) #6771076
Stas I. wrote:
> I tried what you had offered and the  PWM 2 doesn't starts synchronous
> with PWM 1, it synchronous for the first time only.
With only 1 counter for both of those PWM outputs they never ever can
get out of synchronicity:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity doublepwm is
    Port ( clk  : in  STD_LOGIC;
           pwm1 : out  STD_LOGIC := '1';
           pwm2 : out  STD_LOGIC := '1');
end doublepwm;
architecture Behavioral of doublepwm is
signal cnt : integer range 0 to 9 := 0;
constant pwmvalue_1 : integer := 5;
constant pwmvalue_2 : integer := 3;
begin
   process begin
      wait until rising_edge(clk);
      if cnt = 9 then  cnt <= 0;
      else             cnt <= cnt + 1;
      end if;
      if cnt = 0 then
         pwm1 <= '1';
         pwm2 <= '1';
      end if;
      if cnt = pwmvalue_1 then
30
         pwm1 <= '0';
31
      end if;
32
33
      if cnt = pwmvalue_2 then
34
         pwm2 <= '0';
35
      end if;
36
37
   end process;
38
end Behavioral;
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
