I need to clarify a question about verilog
Guest #6757146
Hello everybody,
I'm studying the primitives in verilog and I don't really see any use
for them. I explain:
Imagine you want to describe an AND gate, what would you do?
a) assign OUT = A & B;
b) and (OUT, A, B);
So what is the true power of primitives? Why do they exist?
I have seen that users can create our own primitives (UDP), but the
reasoning I have is the same: Why use this option of the verilog if we
can describe our circuit with a "module"?
Thanks
Guest #6757267
But, if we have:
b) and (OUT, A, B);
both are gate-level descriptions, aren't they?
Guest #6757450
> b) and (OUT, A, B);
a) looks more behavioral, it could be iplemented with a mux-module also;
i.e.
mux(OUT (OUT), .sel (a), IN1 ('0'), IN2 (B))
and therefore with a different gate
Guest #6757665
I think I understand your explanation, so if I want to implement an AND
gate in an FPGA it is absurd to use primitives right? Because FPGAs are
going to use their Logic Blocks for it.
Then, the use of primitives is done in the description of ASICs, right?
Guest #6757956
As i understand it, primitives can be defined for much more complex
descriptions. It makes no sense for a simple gate, but this is a very
simple primitive.
With complexer primitives it will save you writing efford as you just
have to use the primitive.
For an FPGA it will somehow be mapped to ressorces available in the
FPGA. For an ASIC it will be mapped to structure components in some Cell
library.
Guest #6758045
What is the purpose of C-Code? - to be translated by a compiler from a
high level description into executable binary code
What ist the purpose of a verilog description? -
A) to VERIfy LOGic, regardless if given as a netlist of circuitry or
logic-equation
AND ALSO
B) to be translated from a (more or less) abstract description into a
netlist
describing (real) circuitry.
The purpose (A)-Simulation of handwritten or generated netlist (with
back propagation) was the first when verilog was 'invented', verilog was
intended to be run in a simulator only.
The purpose (B) -Synthesize were later add to the 'use-case' of
verilog-coded hardware descriptions.
It seems, that purpose (A) is mostly forgot by today's user, they are
confused with the use of computer programming language as C.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
