Data section exceeds available space in board
OP #6747944
I'm making a small game on LCD from Stone recently and I want to use
Arduino UNO to do it. My code compiles without problems, but when I
upload it, I get an error like the one shown in the picture, is it
because I have too many variables defined?
Can someone please tell me how to fix it?
Arduino:1.8.12 (Windows 10), Development board: "Arduino Uno"
The project uses 6336 bytes, which occupies (19%) of the program storage space. The maximum is 32256 bytes. data section exceeds available space in board
Global variables used 3046 bytes, (148%) of dynamic memory, leaving -998 bytes for local variables. The maximum is 2048 bytes.
There is not enough memory; visit the following URL to follow the instructions to reduce memory usage.
http://www.arduino.cc/en/Guide/Troubleshooting#size
Error while compiling for development board Arduino Uno.
Turn on in File -> Preferences
"Show detailed output during compilation" option
This report will contain more information.
Moderator (Company: Titel) #6747956
Thats the actual problem: you have one or some big (text) arrays or
pictures or something else with need for RAM in your code.
Attach your code as a file, then its easy to say where the problem is
located.
> And I don't know why the code looks like this
Some kind of rendering problem since the last change of the forum
software.
Guest #6748001
Maybe you can leave some constant data in flash space. PROGMEM is the
magic word. But without source code no one could tell.
Moderator (Company: Titel) #6749074
As expected: those "constant" strings are located in RAM. Each of the 44
strings is over 90 chars long and so its easy to see, that they sum up
to nearly 4k. The whole magic is here, that the compiler does some
optimizations to reduce that size to only 3k...
flip wrote:
> transfer these strings into program mem.
Thats the best way, because even when you keep them in RAM they are in
the program mem also, as they are needed to initialize the RAM at
startup.
But I would not stupidly transfer those strings to FLASH/PROGMEM.
Instead I would look for similarities and doubles and place them only
one time in the FLASH/PROGMEM.
So the strings
"ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":"
and
"ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":"
are used throughout the whole program several times. Its enough to
define them only once.
Or even more: those two parts of that strings are the same:
"ST<{\"cmd_code\":\"set"
and
"\",\"type\":\"widget\",\"widget\":"
so only the two parts "enable" and "image" must be changed.
OP #6750181
> So the strings
> and
> It's enough to define them only once.
I think what you are saying can be implemented, except that I need to
modify the code to add loops or arrays? I'll try following your
direction.
Moderator (Company: Titel) #6750323
Cliff W. wrote:
> except that I need to modify the code
For sure.
Why loops?
Try it somehow like that:
char str_enable[] = "ST<{\"cmd_code\":\"set_enable\",\"type\":\"image\",\"widget\":";
char str_image[]  = "ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":";
    Serial.print(str_image);
    Serial.println("\"image2\",\"image\":\"circle\"}>ET");
    Serial.print(str_enable);
    Serial.println("\"button1\",\"enable\":false}>ET");
    Serial.println("\"image1\",\"image\":\"circle\"}>ET");
    Serial.println("\"button2\",\"enable\":false}>ET");
Of course also you cold simply look for the F() macro and use it in the
Serial.println() function call.
Start a new thread
