High voltage divider circuit to run an LED?
OP (Company: KUKE Electronics CO., Limited) #6730705
Good day, all
Recently, I have a system running at 62V max, 54V nominal based on
voltage divider formula. I wanted to have a little alert LED, so I was
thinking about using 10, 1kohm resistors, and adding the LED bewteen the
9th and 10th (or 1st and 2nd, if it matters), to get at most 6V and just
a few mA.
Is a better/easier way? Is this a really crappy way? Or is this a
perfectly fine way?
OP (Company: KUKE Electronics CO., Limited) #6730766
I have a bunch of 1k, 1/4W resistors, so 10 of those will work fine. I
guess that 6mA at 60V is only 360mW, which might be a bit high. I could
always use a lot more resistors and experiment by reducing it until I
get to a suitable brightness.
Guest #6730798
You want, thst the LED turns off if the voltage drops below 54V ?
You need a much sharper transition, so you need some amplifing circuit.
People usually take TL431, but it can withstand only 36V. So a voltage
divider is also part of the circuit.
Guest #6730861
As Helge said: you only need a series resistance.  A resistor parallel
to the LED is not required.
As you calculated correctly, for 6mA at 60V[1] you need a 10k resistor
which will dissipate 360mW.  To spread that you could use multiple
resistors, either in parallel (i.e. 10 x 100k) or in series (i.e. 10 x
1k) or any combination which gives 10k.  If the resisistors are equal,
the power will be spread equally, i.e. with 10 resistors, each one
dissipates 36mW.
Well, you waste 360mW to light a LED with 10-20mW ...
[1] actually 60V minus the Vfwd of the LED (1.8-3V)
OP (Company: KUKE Electronics CO., Limited) #6736546
The series resistor drops voltage to control the current through the LED
- the current through the LED is the important parameter. The forward
voltage of the LED must be used to calculate the series resistor. Red
LEDs have a forward voltage of about 2.2 volts. White LEDs have a
forward voltage of around 3.7v - it depends on the color and chemistry
of the LED. Is that right?
Start a new thread
