CAN Frame timing network
OP #6724310
1. How is CAN frame timing handled in Can network ?
Is it cyclic or triggered? How is frame handled in HMI interface like
button ress from an user? How do you ensure that signal pressed is not
missed?
What is repetition time and inhibit time concept to send frame ?
2. Repetition time : This is the standard transmission time for every
PGN, if no signal value was changed.
3. Inhibit time The inhibit time is the minimum time between two
transmissions of the same PGN.
I didnot understand what 2 and 3 means ? can someone please give an
example?
#6724339
It can be cyclic or triggered or a combination of them. For example,
you'd send 'no change in buttons state' periodically every 250msec, but
send a triggered frame on change of the button status.
With this concept alone, pressing x>2 buttons slightly one after the
other, would generate x triggered messages. This wastes bus load and
uses up full bus capacity in a short time span.
To avoid that, after every change of button status a inhibit time e.g.
50msec before sending new triggered or the next periodic frames is
inserted.
br mf
Start a new thread
