Soldering station Ersa RDS-80
Guest #6644667
• ▲ useful
▼ not useful
false friend wrote:
> OSchlaffel wrote:
>> Eventually
> Mal nachschlagen!
My dear mister choral society, I think I am spidering, why are you
making down your collegue in full trains. His tip shines to be first
cream. I would like to let me out but I will make me on the socks.
Guest #6644680
• ▲ useful
▼ not useful
Leonid S. wrote:
> OSchlaffel wrote:
>> В итоге BAS81, 82, 83, 85, 86
> Many thanks.
Hello Leonid,
the BAS8x could possibly be that diode you're looking for. MELF diodes
with one grey stripe is only the BAS8x ones.
Actually, as I saw, are these ones only awailable from Vishay, note,
that this ones from Vishay have a black stripe instead of the grey one.
But the parameter should be equivalent as can be seen in the datasheet.
Verify therefore other photos of the RDS80 board. You'll find some with
that diode have a black stripe.
But could you find out why the diode has become faulty?
The SOT23 device (possibly a transistor), which is connected to that
diode, could be faulty too.
You also have to check other components become possibly faulty.
What is the matter with that soldering station?
Regards
Guest #6645109
• ▲ useful
▼ not useful
With me is not good cherry eating wrote:
> My dear mister choral society, when I read this I looked stupidly out of
> the laundry. It is not sausage, because of language like this the forum
> is  transforming into a juice shop.
You are great! You made me laugh head off. What a pity, Englishmen will
not really understand your great jokes. Please keep on joking in the
"juice shop"!
OP #6645448
• ▲ useful
▼ not useful
OSchlaffel wrote:
> Вы также должны проверить, что другие компоненты могут быть
> неисправными.
> Что с той паяльной станцией?
  The station has been operating for over 10 years. She began to
experience similar symptoms described here:
https://www.fingers-welt.de/phpBB/viewtopic.php?t=7176
Similarly, the 3b smd pnp transistor sot-23 (bc856) and this unknown
diode were heated.
   All other elements are working and this transistor next to the diode
is also working. I assume that the transistor opens when the triac is
closed by the command from the processor for
 supplying voltage +5 v at the time of measuring the resistance of the
soldering iron heater.
   Also, for this unknown diode at a certain moment, a voltage of 24V is
suitable.
the soldering iron heats up when the triac is closed.
   There were cases when the plug came off when working with the
soldering station
soldering iron cord. Perhaps at this moment without load, the process
failed and both voltages + 5v and an alternating voltage of 24v were
encountered on this ill-fated diode, which was the result of a
malfunction.
    Apparently it was a Schottky diode, I put 1N4148. The station is
working properly now, time will tell.
Guest #6645515
• ▲ useful
▼ not useful
Hi Leonid,
nice to hear that your soldering station is now working.
With a 1N4148 it should be functioning as well as withe the BAS8x ones.
But if you order some parts in the future so also place some BAS8x ones
to your order Maybe the 40V (BAS81) type should be good enough, but I
would choose the 60V (BAS83) to ensure a safety margin.
Than by time I would replace the 1N4148 by the BAS83.
Regards
#7506977
• ▲ useful
▼ not useful
Leonid S. wrote:
The diode is in the voltage divider, and takes an active part in measuring the resistance heating element of the soldering iron. From characteristics depends temperature.
somebody now the exact numbers of the thing i just can read thats a ATMLH820 but can not read anymore is short the numbers the other thing is that i can't find somthing with ATMLH820 found something with ATMLH822 i am not sure if is the same .
#7517987
• ▲ useful
▼ not useful
So it seems this is about the EEPROM bottom left on your attached pic?
No guarantees, I often just quickly glare over the contents of sites and documents
So "ATMLH820" is just "ATMH" + date code and is not sufficient info to identify that EEPROM, because you can find different Atmel products with "ATMLH820"
But here are some indicators for what that part could be, NO GUARANTEES
Here somebody states that it is an Atmel 24C02, alongside your picture of the pcb. He writes "Speicher: Atmel 24C02". One can barely see the characters of the second line, but looks like "24C02BN" to me
Beitrag "Re: RDS-80 verhält sich seltsam"
Here there is a pcb from elektroda.pl that seems to look like the one you are showing, but there is an EEPROM from ST on that spot, an ST 24C02, which maybe might be compatible to your Atmel chip see also attachment
https://www.elektroda.pl/rtvforum/topic3450385.html
So maybe your part might be an AT24C02x, based on all the above
Just to show an example of an AT24C02, the first attachment shows an Atmel 24C02B with date code "ATMLH820" and product code "02B"next to the data sheet marking info
Atmel 24C02b data sheet
https://ww1.microchip.com/downloads/en/devicedoc/doc5126.pdf
Source for the Atmel 24C02 pic https://romiani.com/product/atmlh820/
Please log in before posting.
or
Registration is free and takes only a minute.
Register now
