Display binary image on vga using VHDL
Guest #6638182
1. Too few information given.
2. Wild guess:
The Image is stored in blocks. The addressing of the image memory lags
behind or the data is behind and so for some clocks old data is being
put on the lines.
But it is strange that the lines are on both sides of the caracters.
Something went horrible wrong.
Did you do simulation? What if you just output a white rectangle, is
that ok?
How is the signal path inside the FPGA, where is the image stored, how
do you output it and what external electronics is involved? Is it
classic VGA or do you just mean the resolution and it is HDMI/DP/...?
Is the Image supposed to look green? Where is the original image? Maybe
the lines are an artistic sideeffect?
Moderator (Company: Titel) #6638264
ElectroCataru wrote:
> How can i get rid of the lines?
First is to find out: where do they come from?
Are they static? Or do they change?
> I just wanna display "PONG" text.
On what platform with what hardware?
Where does this "PONG" text come from?
Do you have 5 bitmaps of those 5 characters somewhere in memory?
Guest #6638672
are static
using a basys 3 and a 1024x768 monitor
i use this site https://www.dcode.fr/binary-image to convert a photo
(jpg) in binary.
Guest #6638677
> 2. Wild guess:
> put on the lines.
> that ok?
classic VGA, with bitmap
yes, it's supposed to look green.
Moderator (Company: Titel) #6639133
> are static
You have the traditional "off-by-one" problem due to latency.
> (jpg) in binary.
Try out some test patterns: half black/half white with top/bottom and
left/right. Try vertical/horizontal lines with one pixel width. Or any
other repeating pattern like squares or hatches.
Try to find out a behaviour and dig this out in simulation.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
