Compile warnings in model sim
Guest #6629803
Hello, I get compile warnings (and later compile errors from other
parts, but one after another...) in model sim with the following code.
I do not get compile warnings when synthesizing the code with Lattice
Diamond nor when compiling it with Active HDL.
What is wrong with the following code?
type TPhOptions is record
sigPrintheadKCE      : std_logic;
sigPH_PICAIIRohm    : std_logic;
sigReg_Chan_Offs_6    : std_logic_vector( 7 downto 0);   sigReg_Chan_Offs_5    : std_logic_vector( 7 downto 0);   sigReg_Chan_Offs_4    : std_logic_vector( 7 downto 0);   sigReg_Chan_Offs_3    : std_logic_vector( 7 downto 0);   sigReg_Chan_Offs_2    : std_logic_vector( 7 downto 0);   sigReg_Chan_Offs_1    : std_logic_vector( 7 downto 0);
sigReg_Words_Per_Ch    : std_logic_vector( 7 downto 0);
sigReg_LineOffs      : std_logic_vector( 7 downto 0);
sigSPI_Clk_Duration    : std_logic_vector( 3 downto 0);
sigSPI_Clk_Duty      : std_logic_vector( 3 downto 0);
sigSPI_DataSwitch    : std_logic_vector( 3 downto 0);
Bit16perLine      : std_logic_vector( 7 downto 0);
sigEnableChannel      : std_logic_vector( 5 downto 0);
REG_Latch_Setup_Time  : std_logic_vector( 7 downto 0);
REG_Latch_End_Time    : std_logic_vector( 7 downto 0);
REG_Strobe_Setup_Time  : std_logic_vector( 7 downto 0);
REG_Burn_Prescaler    : std_logic_vector( 7 downto 0);
sigReg_HeadFill32    : std_logic_vector( 7 downto 0);
end record;
-- then usage of length attribute in following constant definition
  constant PH_OPTIONS_LEN: integer :=
    1 +
    1 +
    work.fpga_configP_helper.TPhOptions.sigReg_Chan_Offs_6'length +
    TPhOptions.sigReg_Chan_Offs_5'length +
    TPhOptions.sigReg_Chan_Offs_4'length +
30
    TPhOptions.sigReg_Chan_Offs_3'length +
31
    TPhOptions.sigReg_Chan_Offs_2'length +
32
    TPhOptions.sigReg_Chan_Offs_1'length +
33
    TPhOptions.sigReg_Words_Per_Ch'length +
34
    TPhOptions.sigReg_LineOffs'length +
35
    TPhOptions.sigSPI_Clk_Duration'length +
36
    TPhOptions.sigSPI_Clk_Duty'length +
37
    TPhOptions.sigSPI_DataSwitch'length +
38
    TPhOptions.Bit16perLine'length +
39
40
    TPhOptions.sigEnableChannel'length +
41
    TPhOptions.REG_Latch_Setup_Time'length +
42
    TPhOptions.REG_Latch_End_Time'length +
43
    TPhOptions.REG_Strobe_Setup_Time'length +
44
    TPhOptions.REG_Burn_Prescaler'length +
45
    TPhOptions.sigReg_HeadFill32'length
46
-- warnings:
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(38): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(39): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(40): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(41): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(42): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(43): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(44): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(45): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(46): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(47): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(48): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(49): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(51): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(52): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(53): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(54): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(55): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
# ** Warning: E:/SAUBER/lfe5um25_octavo/impl1/source/fpga_configP.vhd(56): (vcom-1260) Type mark (TPhOptions) cannot be prefix of selected name.
Guest #6635387
And this is how it works:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity test_record is
end test_record;
architecture tb of test_record is
30
31
end record;
32
33
signal REC : TPhOptions;
34
35
constant REC_LEN : integer :=
36
  1 +
37
  1 +
38
  REC.sigReg_Chan_Offs_6'length +
39
  REC.sigReg_Chan_Offs_5'length +
40
  REC.sigReg_Chan_Offs_4'length +
41
  REC.sigReg_Chan_Offs_3'length +
42
  REC.sigReg_Chan_Offs_2'length +
43
  REC.sigReg_Chan_Offs_1'length +
44
  REC.sigReg_Words_Per_Ch'length +
45
  REC.sigReg_LineOffs'length +
46
  REC.sigSPI_Clk_Duration'length +
47
  REC.sigSPI_Clk_Duty'length +
48
  REC.sigSPI_DataSwitch'length +
49
  REC.Bit16perLine'length +
50
  REC.sigEnableChannel'length +
51
  REC.REG_Latch_Setup_Time'length +
52
  REC.REG_Latch_End_Time'length +
53
  REC.REG_Strobe_Setup_Time'length +
54
  REC.REG_Burn_Prescaler'length +
55
  REC.sigReg_HeadFill32'length;
56
57
begin
58
59
process begin
60
  wait for 10 ns;
61
  report "REC_LEN: " & integer'image(REC_LEN);
62
  wait;
63
end process;
64
65
end;
Alles Gute alles Liebe (-:
Guest #6635402
Wahhhh!!!! the "highlighted code" function just renders as bad as inline
code. don't click that!
The image shows how the code is supposed to look - and did before the
forumsoftware was "schlimmbessered".
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
