Forum: FPGA, VHDL & Verilog get some outputsignals if cnt reaches an exact amount
von Steven Tumler (Guest)
Hello Guys
I got a Problem. I made a shift register who is counting from 0 to 12
over and over and Some Outputs.
It looks like this:
entity Ampel is
    Port ( ROT : out  STD_LOGIC;
           GRÜN : out  STD_LOGIC;
           GELB : out  STD_LOGIC;
           cnt : inout integer range 0 to 12:=0;
           clk : in  STD_LOGIC);
end Ampel;
architecture Behavioral of Ampel is
begin
process (clk)
begin
if rising_edge (clk) then
  if cnt=12 then cnt <= 0
   else
   cnt <= cnt + 1;
    end if;
  end if;
end process;
end Behavioral;
If cnt = 0 - 4 ROT should be 1
if cnt = 5 GELB and ROT should be 1 and so on..
could anyone migth help me with this Problem ?
von -gb- (Guest)
ROT <= '1' when cnt < 5 else '0';
Too unspecific.
> GRÜN
Contains "Ü" which may cause Problems.
Use the [vhdl] Tags for VHDL Code.
Where the heck did you find this lazy coding style?
Is it your own way of reducing lines of code?
Short: never ever use a port as a signal. You will encounter strange
problems in simulation later on.
 What problems do you encounter? What do you want to happen? And what
else happens instead? What error messages are reported by which
toolchain?
You could use the German FPGA forum of µc.net if thats more convenient
for you:
https://www.mikrocontroller.net/forum/fpga-vhdl-cpld
