How to implement lookup table in VHDL
Guest #6596690
What is the fastest / most efficient way to generate a lookup table in
VHDL? I have a nonlinear function which I would like to implement and my
data is currently available as an array in Matlab. For the lookup table
I intended to us a simple case statement but that implies that I had to
manually code all the different cases in the VHDL editor, i.e. filling
in the data of the table manually into the source file.
Is there a proper way how this is done? The only way I see so far would
be, to write a MATLAB script which prints the VHDL code based on my data
array into a file. This would probably work but seems to be reinventing
the wheel since I'm for sure not the first one who has to generate a
lookup table in VHDL. So what's the correct solution for such a task?
Guest #6596766
wouldn't it be an option to use a RAM-structure (e.g. a BRAM) als
lookup-table? And your Matlab-script just provides an
initialization-file for the RAM.
#6596807
Your idea to generate VHDL from Matlab is quite common and I would say
it is also quite efficient. (You can even throw money at Mathworks and
get toolboxes that do that for you).
Instead of generating a huge switch case statement I would actually
export it as table. Define a two dimensional type that fits your table
data (define that type as well if it makes live easier). Then export
your table as a constant with initialization.
All of this goes into a VHDL package, which makes it possible to include
it in other files of your VHDL design. This is important to separate
manually written and generated files.
Guest #6598877
Thanks for all the inputs.
This is how I solved it now since it seemed at least not to be the most
stupid solution.
Jürgen S. schrieb:
> I'd prefer a MIF to be generated. The Synthesis can move this to a
> LUT-only implementation at any point of time. At least if you disallow
> BRAM usage.
What is a MIF? Google suggested "memory configuration file", I guess
that is what you referred to?
I will definitely have an eye on the other possibilities too once I find
the time to do so.
Guest #6599227
Unfortunately, you gave too less information to answer this question
precisely. Are you planning only simulation with the VHDL model? Are you
targeting FPGA? Which FPGA? Are you planning ASIC implementation? Shall
the code be technology independent?
For Xilinx FPGA, it may be a good idea to generate a block ROM macro, as
described in the Xilinx Vivado Design User Guide (UG901), Section "ROM
HDL coding Techniques". Since it is all HDL code, you can generate is
completely from MatLab. But this is only one possible solution. It does
not work for ASIC and for simulation-only models there are easier ways
to go.
Guest #6828226
> lookup-table?
Every LUT in an FPGA IS RAM.
Take a 6-Input Lut. It stores 2^6 Bits Memory, has 6 Address Inputs and
1 Data Output.
So BRAM is ofcourse a good way to implement larger LUTs with wider
Datawidth and deeper Depth. Just store the values in the right order
inside the BRAM.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
