Error when running modelsim
Guest #6540159
Hello,
for a school assignment I have to design a small ALU in vhdl which is
able to run some basic instructions, this is made in quartus II web
edition.
When I compile and analyze the file with quartus no syntax errors are
found, but when running the model sim I get an syntax error.
I have already tried renaming the variables of the entity and re writing
the code in different ways but I just cant get it to work.
This is the error displayed in the modelsim log:
# do ALU.do
  # ** Warning: (vlib-34) Library already exists at "work".
  # Model Technology ModelSim ALTERA vlog 10.1d Compiler 2012.11 Nov  2
2012
  # -- Compiling module ALU
  # Top level modules:
  #   ALU
2012
  # -- Compiling module ALU_vlg_sample_tst
  # -- Compiling module ALU_vlg_check_tst
  # ** Error: ALU.vt(62): near ",": syntax error, unexpected ','
  # ** Error: c:/altera/13.0sp1/modelsim_ase/win32aloem/vlog failed.
  # Executing ONERROR command at macro ./ALU.do line 4
I have attached the vhdl file and the generated vt file.
Thanks and regards,
Mart
Moderator (Company: Titel) #6540211
Trying is not really a useful or reliable way to get to a desired point.
Never ever do this:
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
Both math libs std_logic_xxx and numeric_std define some similar data
types and some similar artihmetic operations with them. You will
encounter some strange problems and weird behaviour now and then.
A hint: only use the numeric_std. It has and it can all you need.
I see some "tricks" due to that:
       tempoutput <=  std_logic_vector(ieee.numeric_std.unsigned(opcode(2 downto 0))) or tempoutput;
Where is line 62?
Strange: a Verilog testbench and a VHDL module. What the heck!
Do you have mixed language support with your Modelsim license?
Guest #6540333
module ALU_vlg_check_tst (
  output,
  sampler_rx
input [7:0] output;
wire [7:0] output;
Problem:
You use output as name, but it is a reserved keyword in verilog.
Solution:
Rename your signals named "output".
Hint:
Replaceing all "output" in the file will NOT do the trick (-:
Guest #6540339
But indeed, very strange, the ALU.vt was generated by Altera Tools ans
does not respect keywords.
Works with the free Modelsim Intel FPGA Starter Edition 2020.1
Guest #6540391
Homework_Service's solution worked! I renamed the output signal to a
other name and the simulation worked fine. Thanks everyone for helping
me out.
Regards,
Mart
Guest #7008958
# Errors: 1, Warnings: 0
# ** Error: c:/intelfpga_lite/20.1/modelsim_ase/win32aloem/vlog failed.
# Executing ONERROR command at macro ./aa.do line 3
Error.
onerror {exit -code 1}
vlib work
vlog -work work aa_top.vo
vlog -work work Waveform.vwf.vt
vsim -novopt -c -t 1ps -L cyclonev_ver -L altera_ver -L altera_mf_ver -L
220model_ver -L sgate_ver -L altera_lnsim_ver work.aa_top_vlg_vec_tst
vcd file -direction aa.msim.vcd
vcd add -internal aa_top_vlg_vec_tst/*
vcd add -internal aa_top_vlg_vec_tst/i1/*
proc simTimestamp {} {
    echo "Simulation time: $::now ps"
    if { [string equal running [runStatus]] } {
        after 2500 simTimestamp
run -all
quit -f
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
