counter with signal enable (active high) and synchronous reset signal (active high)
Guest #6526988
• ▲ useful
▼ not useful
I'm trying to do the following task, but I need your help or some
pointers:
Write a counter with signal enable (active high) and synchronous reset
signal (active high) to a VHDL file (cont_clk.vhd).
The counter should generate an end of count (rco) output signal that
turns high every 1 millisecond and which is active for one clock cycle
(clk). It should also generate a count signal (q) of 14 bits.
Use the counter scheme (sequential circuit) described below.
The module should have the following entity declaration:
entity cont_clk is
 Port (enable: in STD_LOGIC;
 reset: in STD_LOGIC;
 clk: in STD_LOGIC;
 rco: out STD_LOGIC;
 q: out STD_LOGIC_VECTOR (13 down 0));
end cont_clk;
Guest #6527046
• ▲ useful
▼ not useful
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity cont_clk is Port(
  enable: in std_logic;
  reset: in std_logic;
  clk: in std_logic;
  rco: out std_logic;
  q: out std_logic_vector(13 downto 0));
end cont_clk;
architecture Behavioral of cont_clk is
constant M: integer:=999999;
signal Data: std_logic_vector(13 downto 0):=(others => '0');
signal rco_buffer: std_logic:='0';
begin
q <= Data;
rco_buffer <= '1' when to_integer(unsigned(Data)) = M else '0';
rco <= rco_buffer;
process begin
  wait until rising_edge(clk);
  if reset = '1' then
    Data <= (others => '0');
  else
30
    if enable = '1' then
31
      if rco_buffer = '0' then
32
        Data <= std_logic_vector(unsigned(Data) +1);
33
      else
34
35
      end if;
36
    end if;
37
  end if;
38
end process;
39
40
end Behavioral;
Depends on:
Clock frequency.
  • [vhdl]VHDL-Code[/vhdl]
