EmBitz - Compiler - Configuration
Guest #6505091
Hello,
my build environment is EmBitz 1.11 (although not shiny and fresh
anymore). As Target Compiler, the outdated ARM GCC Compiler (EmBitz -
bare-metal) is used, while the ARM GCC Compiler (generic) Target is been
utilized to build and start Windows executables.
(Debugging Windows targets is not possible in this configuration. When I
asked in the EmBitz forum back then, the answer was just "why should
anyone want to do that anyhow???", so for Windows exe debugging, I use
Eclipse CDT standalone debugger.)
However, it's time to get a newer ARM-GCC, but of course, I do not want
to dispense the MinGW compiler for Windows executables.
Does one of you know, if there is a way to change the compiler Flags of
any of the other Compilers or add own Compilers? Is there a way to
define you own Compiler flags?
Guest #6505111
Right Click on your Project -> Build Options -> TAB C Flags
Here you can choose following categories:
General
Debugging
Warnings
Language Standard
C++ options
ARM CPU architecture
ARM FPU architecture
There you can set hundreds of compiler flags - everything gcc has to
offer.
P.S.
Walter, warum fragst Du im englischsprachigen Forum nach, wo man im
deutschsprachigen Forum schon anhand der weitaus höheren Zahl an Threads
erkennen kann, dass Du dort viel mehr Leser erreichst?
Guest #6505138
> offer.
The available flags depend on the selected compiler. (ARM Keil RIView
Compiler has other flags than ARM GCC.) So the available compilers and
flags might be configured somewhere.
If there is no way to configure those, "AVR GCC" seems to be the closest
one available.
Start a new thread
