I'm trying to transfer some Abel code into VDHL. From the code it looks like an 8 bit parallel in parallel out shift register, I'm trying to draw a logic diagram first so that I can then transfer it to VHDL. Any reference or tips will be appreciated it. //inputs SPI0_CS3 Pin 92 istype 'input'; // outputs SPI0_MISO Pin 66 istype 'com'; //Nodes D0,D1,D2,D3,D4,D5,D6,D7 Node istype 'reg_d'; XEN = [Data0,Data1,Data2,Data3,Data4,Data5,Data6,Data7]; OUT = [D7..D0]; equations D0.D = (!SPI0_CS3 & SPI0_MOSI) # (SPI0_CS3 & D0.Q); D1.D = (!SPI0_CS3 & D0.Q) # (SPI0_CS3 & D1.Q); D2.D = (!SPI0_CS3 & D1.Q) # (SPI0_CS3 & D2.Q); D3.D = (!SPI0_CS3 & D2.Q) # (SPI0_CS3 & D3.Q); D4.D = (!SPI0_CS3 & D3.Q) # (SPI0_CS3 & D4.Q); D5.D = (!SPI0_CS3 & D4.Q) # (SPI0_CS3 & D5.Q); D6.D = (!SPI0_CS3 & D5.Q) # (SPI0_CS3 & D6.Q); D7.D = (!SPI0_CS3 & D6.Q) # (SPI0_CS3 & D7.Q); OUT.CLK = SPI0_SCLK; XEN.D = OUT.Q; XEN.CLK = SPI0_CS3;
Jose wrote: > it looks like an 8 bit parallel in parallel out shift register It is all in one: a PiSo (parallel in serial out) and also a SiPo (serial in parallel out). As that it can be connected as a SPI slave device. This SPI uses 3 signal wires: 1. the SPI0_SCLK is the SPI shift clock 2. the SPI0_CS3 is the low active Slave Select aka SS# 3. the SPI0_MISO is the "Master In Slave Out" seriel output data line 4. the SPI0_MOSI is the "Master Out Slave In" serial input data line Knowing that you will find some similarities with that code: http://www.lothar-miller.de/s9y/archives/31-SPI-Slave-im-CPLD.html Try Google translate, but you will get the just by reading those few liens of code. Jose wrote: > I'm trying to draw a logic diagram first so that I can then transfer it > to VHDL. Do that.
