R Shiny: Creating factor variables and defining levels
OP #6470938
I trying to create a machine learning application with Shiny.
In this application, the user can select the specifications of the input
variables (via. input widgets) which will be used to give an estimate of
a response variable. To do this, I have created a data frame from the
selected inputs and save it locally as a data table.
A problem arises when I load the data table again since this will cause
all categorical variables to become character variables. I can however
change these manually with the factor() function and use the levels=
specification.
The problem is that I don't want to manually do this every time a new
dataset gets used, since most likely will change the position of the
categorical variables in the dataset. There will also most likely not be
the same amount of categorical variables in a new dataset.
The data frame "DATA" is the main dataset that contains the response
variable in column 1.
The data frame "test" is the data frame constructed from the selected
inputs, which will be used as the test set for prediction and will
contain only 1 specified observation. This data frame will always have
the response variable as the last column in the data frame, due to how
the data frame is constructed. So the factor variable in DATA[,5] will
always correspond to the previous column in the test data frame:
test[,4].
It is the test data frame that needs the factor levels to be specified
since it doesn't automatically know the number of categories when it
only contains 1 observation.
test[4] <- factor(test[4], levels = unique(DATA[,5]))
I'm trying to write a code that will apply the factor function on all
character variables in the dataset and specify the levels no matter the
position of the character variable in the dataset.
Here is the code I have written so far:
library(shiny)
library(tidyverse)
library(shinythemes)
library(data.table)
library(RCurl)
library(randomForest)
library(mlbench)
library(janitor)
# Read data
DATA <- BostonHousing
# Rearrange data so the response variable is located in column 1
DATA <- DATA[,c(names(BostonHousing)[14],names(BostonHousing)[-14])]
# Creating a simple RF model
model <- randomForest(medv ~ ., data = DATA, ntree = 500, mtry = 4, importance = TRUE)
# UI -------------------------------------------------------------------------
ui <- fluidPage(
  sidebarPanel(
    h3("Parameters Selected"),
    br(),
    tableOutput('show_inputs'),
    hr(),
30
    actionButton("submitbutton", label = "calculate", class = "btn btn-primary", icon("calculator")),
31
    hr(),
32
    tableOutput("tabledata")
33
34
35
  ), # End sidebarPanel
36
37
  mainPanel(
38
39
    h3("Input widgets"),
40
    uiOutput("select")
41
42
  ) # End mainPanel
43
44
) # End UI bracket
45
46
47
48
# Server -------------------------------------------------------------------------
49
server <- function(input, output, session) {
50
51
# Create input widgets from dataset
52
  output$select <- renderUI({
53
    df <- req(DATA)
54
    tagList(map(
55
      names(df[-1]),
56
      ~ ifelse(is.numeric(df[[.]]),
57
               yes = tagList(sliderInput(
58
                 inputId = paste0(.),
59
                 label = .,
60
                 value = mean(df[[.]], na.rm = TRUE),
61
                 min = round(min(df[[.]], na.rm = TRUE),2),
62
                 max = round(max(df[[.]], na.rm = TRUE),2)
63
64
               no = tagList(selectInput(
65
66
                 label = .,
67
                 choices = sort(unique(df[[.]])),
68
                 selected = sort(unique(df[[.]]))[1],
69
70
71
72
73
74
75
# creating dataframe of selected values to be displayed
76
  AllInputs <- reactive({
77
    id_exclude <- c("savebutton","submitbutton")
78
    id_include <- setdiff(names(input), id_exclude)
79
80
    if (length(id_include) > 0) {
81
      myvalues <- NULL
82
      for(i in id_include) {
83
        myvalues <- as.data.frame(rbind(myvalues, cbind(i, input[[i]])))
84
85
86
      names(myvalues) <- c("Variable", "Selected Value")
87
      myvalues %>%
88
        slice(match(names(DATA[,-1]), Variable))
89
90
91
92
93
# render table of selected values to be displayed
94
  output$show_inputs <- renderTable({
95
    AllInputs()
96
97
98
99
# Creating a dataframe for calculating a prediction
100
  datasetInput <- reactive({
101
102
    df1 <- data.frame(AllInputs(), stringsAsFactors = FALSE)
103
    input <- transpose(rbind(df1, names(DATA[1])))
104
105
    write.table(input,"input.csv", sep=",", quote = FALSE, row.names = FALSE, col.names = FALSE)
106
    test <- read.csv(paste("input.csv", sep=""), header = TRUE)
107
108
109
# defining factor levels for factor variables
110
    test[4] <- factor(test[4], levels = unique(DATA[,5])) # <- This line will cause problems if multiple factors in dataset or if different column location
111
112
113
# Making the actual prediction and store it in a data.frame
114
    Prediction <- predict(model,test)
115
    Output <- data.frame("Prediction"=Prediction)
116
    print(format(Output, nsmall=2, big.mark=","))
117
118
119
120
# display the prediction when the submit button is pressed
121
  output$tabledata <- renderTable({
122
    if (input$submitbutton>0) {
123
      isolate(datasetInput())
124
125
126
127
128
} # End server bracket
129
130
131
132
# ShinyApp -------------------------------------------------------------------------
133
shinyApp(ui, server)
Pursuing ML course -
https://intellipaat.com/machine-learning-certification-training-course/
This topic is locked and can not be replied to.
