DC-DC-Boost-Converter
Guest #6452647
• ▲ useful
▼ not useful
I want to run a brushless dc 5v fan off of a thermoelectric generator.
the obvious circuit is a 5V boos converter like this:
https://de.aliexpress.com/item/1005001556639784.html?spm=a2g0o.productlist.0.0.5b055f0eyF8s6O&algo_pvid=f5c583b5-3037-44c7-b8cd-ad5c88a015e6&algo_expid=f5c583b5-3037-44c7-b8cd-ad5c88a015e6-46&btsid=0bb0623b16033199194914446e0469&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Lets say the Fan is deisgned for 5V and 200mA: 1Watts
I am expecting the fan to run at lower Voltages too. I still dont know
the minimum Voltage to start the fan.
I want to convert the voltage efficiently for low power scenarios too.
Lets say the TEG is producing 0.2W. How do i design the DC-DC Converter
to do that? Are there converter cuircits ready?
lets say the TEG is providing 0,2 volts. at 0.05W.
1. i dont need to boost the voltage to 5V
2. i dont want to discharge the capacitor in discontinous mode?
what type of circuit is the most efficient in this scenario? For TEG i
have to think about Load Matching too.
Guest #6452666
• ▲ useful
▼ not useful
If the Fan needs a current running through the motor windings to turn
the blades. And the windings have a resistance for the current.
With this fan, you need to apply 5 V across the motor, that 200 mA of
current are forced against the resistance of the windings.
A lower voltage will not be able to force the same amount of current
through the windings which is needed to turn the blades.
Also:
If the motor hat 1 W of nominal power, this has to be satisfied. At
least in part. you may be able to run the motor at 4 Volts and a bit
lower current, but the blades will turn slower. 0.2 V is not nearly
enough. Yes, you can step up the voltage from 0.2 V to 5 V, but the
current is reduces by the same factor.
Say your source can provide 0,2 V and 0.05 W. This means it can provide
0.25 A @ 0.2 V.
The wattage does not change, but you step up the Voltage to 5 V, then
the source can provide ideally 0.01 A. Because 5 V times 0.01 A is the
0.05 W.
But 0.01 A will not turn the motor.
Guest #6452671
• ▲ useful
▼ not useful
I do understand that aspect.
Its just that i DO want it to be able to run at very low power and low
voltage too. I want the TEG to run the Fan succesfully even at very low
power outputs from the TEG. Thats the most important thing in my little
project.
Guest #6452684
• ▲ useful
▼ not useful
Why do you expect this? There is no rational reason to expect something
like this.
> I still dont know
Doesn't matter at all. For an useful BLDC driver the only target is to
reach the designated rotation speed. It allways uses the whole available
voltage, but controls the effective current (and by the way indirectly
the the power consumption and finally the rotation speed) by PWM.
There is nothing to convert. The fan will use allways exactly the power
required to reach and keep the designated rotation speed. Exactly this
is, what an BLDC driver does.
But, there is a problem for very low rotation speeds. For those cases
most BLDC drivers cannot work, because regulation feedback by EMK isn't
large enough to perform a proper speed regulation. For such cases you
need fans with extra sensors for rotation speed measurement and BLDC
drivers with support for such sensors.
Guest #6452685
• ▲ useful
▼ not useful
x3oo wrote:
> Thats the most important thing in my little project.
I understand. Then you have to use/select a fan which runs at the same
or a lower power which the output power of the TEG.
The fan cannot use more power than the source can provide. This would be
in conflict with physics.
Guest #6452694
• ▲ useful
▼ not useful
> to do that
just like an over unity engine, a perpetuum mobile.
 No, you're the first one, run to patents office.
You need 25 of them. Connect them in series to boost the voltage.
Guest #6452708
• ▲ useful
▼ not useful
>> to do that
Sry there is a misunderstanding. A small Fan for 5V will run at 4V at a
slower speed. I dont want to break physics, i just want to be able to
run the fan at low power output too, (at slower speed)
Guest #6452709
• ▲ useful
▼ not useful
sry, misunderstanding. the fan ist designed for 0.5 W
if the TEG only provides 0.25 W at that moment i want to be able to run
the fan at a slower speed at 0.25W
The TEG only provides very low voltage at 0.25W, thats why i think i
need a boostconverter.
Guest #6452933
• ▲ useful
▼ not useful
c-hater wrote:
> For such cases you need fans with extra sensors for rotation speed
> measurement and BLDC drivers with support for such sensors.
The fan is most likely build like a cheap PC fan, with a 4 pin IC with
integrated hall sensor to controll the motor and little more in it.
Guest #6452934
• ▲ useful
▼ not useful
you need a very special converter. It has to be able to run (and start)
from a very low voltage. it also has to implement some kind of MPP. A
normal boost will cause the input voltage to collapse due to its current
consumption which exceeds the current the TEG can provide.
Guest #6452939
• ▲ useful
▼ not useful
you could try to find some energy harvesting Chip. there should be some
breakout boards available, maybe you can adapt one of those.
to get the fan running, you will definitely need an energy storage, a
big capacitor should be enough. the problem is to get it to start
running, which requires a lot more current (and voltage) than to simply
keep it running.
Guest #6452942
• ▲ useful
▼ not useful
sorry for the multiple posts, i got a spam warning and couldnt figure
out why:
Your Post Seems To Contain Spam: "C i a l i s"
probelm seems to be the combination of spec-ialised, avai-able, onl-ine
and ener-gy or something like that
Start a new thread
