How to properly multiply signed and unsigned
Guest #6425243
• ▲ useful
▼ not useful
I stumbled over this several times now and would like to know how to
properly do this in VHDL: I have a signed number and would like to
multiply this with a positive factor (which is given by an unsigned).
VHDL does not allow me to multiply signed with unsigned. What I did so
far:
- Convert unsigned into std_logic_vector
- Append leading zero bit
- Convert into signed. Since the first bit is always zero, I know no
that the number is always positive, although represented with a signed
type.
This process works but seems retarded to me. I googled how to do this
properly but surprisingly didn't find a lot, although I can't believe
I'm the only one having to do this.
Any hint on how to write this in a clean proper way?
Guest #6425250
• ▲ useful
▼ not useful
Very bad idea, IMO.
I would convert the unsigned number also to signed and do than the
muplitply.
If it's necessary to expand the vector size the function 'resize' will
help.
And I strongly suggest only use the signed/unsigned types from
ieee.numeric_std.all library.
Duke
  • [vhdl]VHDL-Code[/vhdl]
