Serializer verilog
Guest #6396057
• ▲ useful
▼ not useful
Hi! I am writing a code for a serializer. The problem is that I have
only 1s as output but I want to see the input bitstream, obviously. Do
you have any suggestion? Thanks.
The code is the following:
// Serializer
`timescale 1ns / 1ps
module serializer (data_in, send, clk, load, rst, data_out);
input wire [11:0] data_in;
input wire send, clk, load, rst;
output reg data_out;
reg [11:0] temp_data_out;
integer i;
integer j;
always @ (posedge clk)
begin
  if (rst) begin
    data_out <= 1'b0;
    temp_data_out <= 12'b0;
  end
  else if (load)
    for(i=0; i<12; i=i+1)
      temp_data_out[i] <= data_in[i];
  else if (send)
    for(j=0; j<12; j=j+1)
      data_out <= temp_data_out[j];
    //data_out <= temp_data_out[0];
    //temp_data_out <= {temp_data_out[10:0], 1'b0};
30
end
31
32
endmodule //end module serializer
The testbench is
`include "serializer.v"
module serializer_tb();
// Declare inputs as regs and outputs as wires
reg [11:0] data_in;
reg send, clk, load, rst;
wire data_out;
// Initialize all variables
initial begin
  clk = 1;       // initial value of clock
  rst = 1;       // initial value of reset
  load = 0;
  send = 0;
  data_in = 12'b110110110110;
  #15 rst = 0;   // De-assert the reset
  #13 load = 1;
  #15 load = 0;
  #5 send = 1;
  #125 send = 0;
  #10 data_in = 12'b100100010001;
  #10 load = 1;
  #15 load = 0;
  #5 send = 1;
  #125 send = 0;
end
// Clock generator
30
always begin
31
  #5 clk = ~clk; // Toggle clock every 5 ns - 100 MHz
32
end
33
34
// Connect DUT to test bench
35
serializer U_serializer (data_in, send, clk, load, rst, data_out);
36
37
endmodule
Moderator (Company: Titel) #6396217
• ▲ useful
▼ not useful
Have a look what a for loop does in Verilog: it produces parallel
hardware. It looks like you expect something entirely different.
BTW:
I assume this here:
Could be cut down to one line:
      temp_data_out <= data_in;
But I may be completely wrong because I'm doing VHDL usually... ;-)
Guest #6396289
• ▲ useful
▼ not useful
you toggle "load" at #13 and #15, but your clock toggles with #5 (and
rising edges with 10). I think you will miss easily signals in that
style
improve your testbench with:
@(posedge clk)
load = 1;
@(posedge clk)
load = 0;
furthermore:
// is the same like
      data_out <= temp_data_out[11];
In a N-serializer you have to use a 1-bit clock and your inputs stays at
the correct time every N cycles or for N cycles.
Guest #6396506
• ▲ useful
▼ not useful
Hi! For what concern the tesbench, in the simulation result I can see
that when load is high, it returns to 0 after 15 ns. So, it is high for
at least 1 clock cycle.
If I write
how I can see as output the whole bit stream? In this way I can see only
temp_data_out[11] and not all the bits in that array
Guest #6396523
• ▲ useful
▼ not useful
Why you commented this line?
This is basically what the serializer should do, shifting out the bits.
Also, in hardware the for loops are unrolled and so all happens in one
clock cycle and the last assignment wins. In your case, the second for
loop always results to 'data_out <= temp_data_out[11]'. Discard the for
loops and try like this:
begin
  if (rst) begin
    data_out <= 1'b0;
  end
  else if (load)
      temp_data_out <= data_in;  //take over the vector
  else if (send)
      data_out <= temp_data_out[11];  //assert the MSBit of the vector at output
      temp_data_out <= {temp_data_out[10:0], 1'b0}; //shift the vector by one bit per cycle
end
Guest #6396546
• ▲ useful
▼ not useful
Yes you are absolutely righ, I commented that line because I was not
sure (I am new in programming so maybe it is easier for me think with
for loop..!) but I was thinking again about it and you confirmed my
thought. Thank you very much!
Moderator (Company: Titel) #6396979
• ▲ useful
▼ not useful
Don't think you are "programming" like a software programmer writes a
program for a computing device. What you are doing is "describing"
hardware using a HDL (Hardware Description Language). So at first you
must have a "picture" of that hardware on a sheet of paper or at least
in your brain. Then you can describe it with Verilog (or VHDL or
whatsoever).
By doing this don't let you betray by "false friends" like that
"for-loop" in the posts above.
But of course this serializer also could be done with a 12:1
multiplexer. So with each clock a counter must count up and then this
counter can be used for indexing the desired bit.
Guest #6407238
• ▲ useful
▼ not useful
Hi guys! I am here again for asking some help. Here I have the testbench
of the serializer (I slightly modify it in order to have random bits as
input). I would like to add a kind of receiver (like a serial-in
parallel-out register) in order to check automatically if the input
parallel data are equal to the output. How can I do this? Thanks
reg [11:0] data_in;
wire data_out;
initial begin
  load = 0;
  send = 0;
  forever begin
    foreach(data_in[ii]) data_in[ii] = $urandom;
    #13 load = 1;
    #15 load = 0;
    #5 send = 1;
    #85 send = 0;
  end
end
// Clock generator
always begin
30
31
end
32
33
34
35
36
endmodule
Guest #6407528
• ▲ useful
▼ not useful
I find out this solution, maybe someone needs it too :)
 initial begin
  load = 0;
  send = 0;
  forever begin
    foreach(data_in[j]) data_in[j] = $urandom;
    #13 load = 1;
    #15 load = 0;
    #5 send = 1;
    #20          //header
    for(i=0; i<12; i=i+1) begin
      #5 reg_sipo[11-i] <= data_out;
      end
    #5 send = 0;
    if(reg_sipo == data_in) check = 0;
    else check = 1;
  end
end
  • [vhdl]VHDL-Code[/vhdl]
