Gray counter verilog
Guest #6386832
• ▲ useful
▼ not useful
Hi guys!
I want to write the verilog code for a 8-bit gray counter. I added in
attach the code and the testbech. For some reason I cannot understand, I
cannot see as outputs the counting, I have only "z" value as output.
Please could you help me? Thank you very much!
Guest #6393206
• ▲ useful
▼ not useful
Thank you! I solved the problem. I want that the counter stops when it
reaches the maximum value until I give a new clear signal. Hence, I
added an "if" but it doesn't work because the counter keeps counting and
then stops when it reaches "10000000". Could you help me?
The code is presented here
 module gray_counter (clk, clear, count, out);
input clk, clear, count;
output wire [7:0] out;
wire clk;
wire clear;
wire count;
reg [7:0] temp_out;
always @ (posedge clk)
begin
  if(clear)
    temp_out <= 8'b00000000;
  else if(count && temp_out != 8'b11111111)
    temp_out <= temp_out + 1'b1;
end
assign out = {temp_out[7], (temp_out[7]^temp_out[6]), (temp_out[6]^temp_out[5]), (temp_out[5]^temp_out[4]), (temp_out[4]^temp_out[3]), (temp_out[3]^temp_out[2]), (temp_out[2]^temp_out[1]), (temp_out[1]^temp_out[0])};
endmodule //end module gray_counter
Guest #6393242
• ▲ useful
▼ not useful
I tried to write
  else if(count && out != 8'b11111111)
instead of
and now it seems working but I cannot understand why.
  • [vhdl]VHDL-Code[/vhdl]
