Forum: FPGA, VHDL & Verilog Why can't I set a (genvar) outside the control section of a loop?
von Kevin S. (kvnsmnsn)
I just wrote a design in Verilog that takes two operands as input,
(leftOp) and (rightOp),  and outputs one operand, (result), where the
common length of all operands is defined by parameter (nmBits), that
defaults to 1. I want to loop through the bits in (result), and make
each the exclusive or of the bit on the opposite side on (leftOp) and
(rightOp). My code is:
module rbwx ( result, leftOp, rightOp);
parameter nmBits = 1;
integer highBit  = nmBits - 1;
output [ highBit:0] result;
input  [ highBit:0] leftOp;
input  [ highBit:0] rightOp;
genvar ix, opp;
for (ix = 0; ix < nmBits; ix = ix + 1)
begin
  opp = highBit - ix;
  xor2 x2( result[ ix], leftOp[ opp], rightOp[ opp]);
end
endmodule
When I run Icarus on this I get:
D:\Hf\Verilog\Unpacked\Common>\Icarus\bin\iverilog -g2009 -o rbwx.out rbwx.sv
rbwx.sv:12: syntax error
rbwx.sv:12: error: Invalid module instantiation
So my design is generating a syntax error right where I assign (opp) to
the difference between (highBit) and (ix). Why can't I do this, since
(opp) is defined as a (genvar)? Can I only use (genvar)s in the control
section of a loop?
von Klakx (Guest)
I think there should also be a generate / endgenerate statement placed
around the for loop.
Accordingly I copied "rbwx.sv" to "klakx.sv" to get:
module klakx ( result, leftOp, rightOp);
genvar ix, opp;
generate
  begin
    opp = highBit - ix;
  end
endgenerate
endmodule
and then I tried this with Icarus and got:
D:\Hf\Verilog\Unpacked\Common>\Icarus\bin\iverilog -g2009 -o klakx.out klakx.sv
klakx.sv:13: syntax error
klakx.sv:13: error: Invalid module instantiation
Looks like the enclosing the (for) loop with (generate) and
(endgenerate) didn't fix the problem.
von Klakx (Guest)
"syntax error" ... icarus is very shy compiler...
localparam is the solution:
localparam integer highBit  = nmBits - 1; // here
genvar ix; // remove opp here
generate
  begin
    localparam opp = highBit - ix; // here
  end
endgenerate
endmodule
Klakx, thanks for that last little bit! It's working just fine now.
