How do you program arm processors?
Guest #6327046
STLink, LPCLink, JLink, BlackMagicProbe,...
there are plenty of programmers. And for SWD/JTAG, there is no
distinction between programmers and debug probes.
Guest #6327106
Jayesh S. wrote:
> But when it comes to ARM, i havent
> found anything on what you need to program / how to program arm chips.
Some chips have a builtin boot-loader: You only need a COM port, for
example a USB-to-serial device like ftdi or other brand. Cheap solution,
somewhat slower than SWD due to the slower bitrate of a COM port.
So, in detail:
- The LPC from NXP, programmable with 'FlashMagic'. Use google,
FlashMagic is free downloadable and usable.
-  The STM32Fxxx, programmable with: my own 'STM32Prog', downloadable on
www.mikrocontroller.net, subforum 'projekte&code', also with old 'erfos'
programmer, also with a piece of software from ST somewhat like
'bootloader demonstrator' or so.
- The chips from Nuvoton are somewhat special: they provide on the chip
a flash-area of 4K bytes or so (called LDROM), which is outside of the
common flash. In this LDROM you can install a bootloader of your own.
Nuvoton provides ready made bootloaders, but I do not know, if they
are pre-programmed in the chips on delivery.
Usually ALL modern Cortex chips are programmable with a suitable
JTAG/SWD programming dongle, as there are: Segger's J-Link (VERY
expensive!), Segger's J-Link-edu (expensive) and China-clones of them
(not expensive, but...)
The original Segger parts also program older ARM devices, which have no
SWD, but JTAG
The Chip-manufacturers (NXP, Nuvoton, ST) use to provide also dongles
like ST-Link, Nu-Link etc. - but this devices usually do the job only
with chips from the particular company.
Finally: using chips with bootloader you only need a cheap standard
electronics like a USB to Serial converter, the programming algorithm is
published and there are at least some independent programming Apps to do
the job. With JTAG/SWD you need special electronics, the programming
algorithms are usually not published by the manufacturers and the good
programmers are expensive or even VERY expensive.
That's it.
W.S.
This topic is locked and can not be replied to.
