4Byte sequence to int
Moderator (Company: Titel) #6320248
• ▲ useful
▼ not useful
Marthy .D wrote:
> I have for example these 4 bytes that I want to convert to int .
> hex:
> [3E 29 C3 39]
Hex is like decimal and like binary just a different view of the same
number.
An integer has 32 bits and a hex digit has 4 bits. Therefore 8 hex
digits are exactly 32 bis and you can simply concatenate the hex values
in some order (lets assume left to right) and interpret it as an
integer:
hex 3e29c339 = bin 111110001010011100001100111001 = dec 1042924345
But maybe the byte order is right to left the integer value is another
one:
hex 39c3293e = bin 111001110000110010100100111110 = dec 969091390
If this answer doesn't help you, then maybe because information is
missing: where does that hex number come from? Is it really a hex number
or is it just a hex view of a binary number?
Guest #6320439
• ▲ useful
▼ not useful
No this is actually what I need thank you very much .
Another question : Is it possible to print a char in VHDL with the use
of report ?
Maybe I didn't search well on the internet but I can't find it. I only
know how to print an integer but not a char .
(Company: Schweigstill IT) #6320448
• ▲ useful
▼ not useful
> one:
And on a PDP-11 and similar computers or processors with mixed endianess
it would be:
hex 39c3293e = bin 001010010011111011100111000011
(Company: Home) #6323992
• ▲ useful
▼ not useful
Marthy .D wrote:
> Hello guys!
> How can we convert a 4 byte to int in VHDL ?
https://www.xilinx.com/support/answers/45213.html
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
entity conv_test is
Port ( a : in STD_LOGIC_VECTOR (7 downto 0);
b : out integer);
end conv_test;
architecture Behavioral of conv_test is
begin
b <= to_integer(signed(a));
end Behavioral;
 Regards Alex.
(Company: Home) #6325248
• ▲ useful
▼ not useful
Alexander S. wrote:
> Marthy .D wrote:
>> Hello guys!
 LIBRARY ieee;
 entity conv_test is
 b : out integer);
 end conv_test;
 begin
 end Behavioral;
  Regards Alex.
 Attached ModelSim project of next VHDL design :
library ieee ;
use ieee.std_logic_1164.all ;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity IntegerConvert  is
port
 ClockIn,
 nResetIn
                     : in std_logic;
 DataIn        -- Data for convert
                     : in std_logic_vector(15 downto 0);
 DataOut        -- Data Out
                     : out std_logic_vector(15 downto 0)
end IntegerConvert;
architecture  ArchIntegerConvert of IntegerConvert is
signal Data : integer range 0 to 65535 := 0;
begin
 Name_Process:
process (ClockIn )
begin
 if(ClockIn'event and ClockIn = '1') then
  case nResetIn is
   when '0' =>
30
    Data     <= 0;
31
    DataOut <= (others => '0');
32
   when others =>
33
    Data     <= conv_integer(signed(DataIn));                -- Convert 4 Bytes to integer
34
    DataOut <= conv_std_logic_vector(Data,16);               -- Convert integer to 4 Bytes
35
  end case;
36
 end if;
37
end process  Name_Process;
38
39
end ArchIntegerConvert;
 Regards Alex.
 P.S.
conv_integer  conv_std_logic_vector in real design isn't need be
clockable.
 It's only exapmle of usebility of convert in VHDL.
Moderator (Company: Titel) #6325282
• ▲ useful
▼ not useful
Do not use the old fashioned and obsolete synopsys arithmetic libs!
Use the  IEEE 1076.3 numeric_std instead.
And never ever use both togehter!
See that:
http://www.lothar-miller.de/s9y/categories/16-Numeric_Std
Its German, but Google translate helps out with a very readable
translation:
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=http%3A%2F%2Fwww.lothar-miller.de%2Fs9y%2Fcategories%2F16-Numeric_Std
(Company: Home) #6325326
• ▲ useful
▼ not useful
Jörg W. wrote:
> Besides:
>> integer to 4 Bytes
> 16 bits just makes for two bytes …
 You are righ :
library ieee ;
-- use ieee.std_logic_unsigned.all;
port
 ClockIn,
 nResetIn
                     : in std_logic;
                     : in std_logic_vector(31 downto 0);
 DataOut        -- Data Out
                     : out std_logic_vector(31 downto 0)
end IntegerConvert;
signal Data :  integer range 0 to 2147483647 := 0;
begin
 Name_Process:
process (ClockIn )
begin
  case nResetIn is
   when '0' =>
30
    Data     <= 0;
31
32
   when others =>
33
    Data     <= conv_integer(unsigned(DataIn));                            -- Convert 2 Bytes to integer
34
    DataOut <= conv_std_logic_vector(Data,32);                          -- Convert integer to 4 Bytes
35
  end case;
36
 end if;
37
38
39
 Regards Alex.
 P.S.
A VHDL integer is defined from range -2147483648 to +2147483647.
https://www.edaboard.com/threads/vhdl-highest-possible-integer.247443/#:~:text=A%20VHDL%20integer%20is%20defined%20from%20range%20%2D2147483648%20to%20%2B2147483647.
(Company: Home) #6325364
• ▲ useful
▼ not useful
  convert in VHDL is not synthesizable virtual function for sintezis
tools.
 Attached example is the only pipe line without arithmetic function.
 See attached picture and Vivado design
 Regards Alex.
Moderator (Company: Titel) #6325669
• ▲ useful
▼ not useful
Try it that way:
 LIBRARY ieee;
 entity conv_test is
 Port ( a,b,c,d : in STD_LOGIC_VECTOR (7 downto 0);
        x,y : out integer);
 end conv_test;
 begin
    x <= to_integer(signed(a&b&c&d)); -- two different byte orders
    y <= to_integer(signed(d&c&b&a));
 end Behavioral;
Alexander S. wrote:
> convert in VHDL is not synthesizable virtual function for sintezis tools.
Where did you find this strange statement?
You do not get the trick at all?
Of course: when you use the OLD and OBSOLETE std_logic_arith, then you
MUST use the OLD and OBSOLETE std_logic_unsigned or the OLD and
OBSOLETE std_logic_signed also.
All I said is: use the numeric_std without any of those OLD and
OBSOLETE Synopsys math packages.
BTW: why the heck do you add latency (aka. flipflops) to a conversion?
  • [vhdl]VHDL-Code[/vhdl]
