Run_length_encoding
Guest #6318212
• ▲ useful
▼ not useful
Our professor is kinda crazy . He gave us a such hard task for a
beginner class We are supposed to swap 2 colors of an image with the use
of Run-length encoding and with the use of VHDL .
I checked this on the internet and there is not a lot of informations or
documents about this RLE .They just explain the lossy compression and
the data compression method of the run length coding and that is all .
Does anyone have an idea about this topic ?
Guest #6318306
• ▲ useful
▼ not useful
Everyone in your class except you ?
An RLE encoded image (bit or byte) stream does clearly say, what color
(index) the next pixels have (it is not lossy). You pass the strean,
except that you modify the color (index) of A to B and ob B to A and let
C D, E... as they were.
Think about the main application of millions of FPGAs, decipher Internet
streams, unpack base64, decode zip, analyze the content and if certain
key words are detected modify the information so that for instance an
HTML page does not display hate speech against the government but keeps
you in your filtered bubble that your country is the greatest in the
world.
Your professor tries to show you exactly this, so that you know where
fake news are coming from.
Guest #6318410
• ▲ useful
▼ not useful
Thank you  MaWin for the explanation .
Swapping randomly two indexes would be ok but how could we identify two
colors?
For example I want to identify the green color and swap it or blend it
with the blue color ? How could that be possible ?
Moderator (Company: Titel) #6318495
• ▲ useful
▼ not useful
Leonardo wrote:
> there is not a lot of informations or documents about this RLE
What is "this RLE"?
What additional information did your professor give you?
> They just explain the lossy compression and the data compression method
RLE ist not lossy. Additionally it is a very, very simple kind of
"compression", and due to that its working only good for pictures with
simple structure and only few colors. The most simple RLE ist something
like
linelength = 15 pixels
2 pixels red, then 5 pixels green, then 8 pixels blue
3 pixels red, then 5 pixels green, then 7 pixels blue
4 pixels red, then 5 pixels green, then 6 pixels blue
5 pixels red, then 5 pixels green, then 5 pixels blue
6 pixels red, then 5 pixels green, then 4 pixels blue
Draw this picture on a sheet of paper if you can't fix it in brain.
A little bit shorter this picture can be written this way:
2 red 5 green 8 blue
3 red 5 green 7 blue
4 red 5 green 6 blue
5 red 5 green 5 blue
6 red 5 green 4 blue
And with red=1, green=2 and blue=3
this results in
2 1 5 2 8 3
3 1 5 2 7 3
4 1 5 2 6 3
5 1 5 2 5 3
6 1 5 2 4 3
And now, if you have to swap red an blue this is
2 3 5 2 8 1
3 3 5 2 7 1
4 3 5 2 6 1
5 3 5 2 5 1
6 3 5 2 4 1
Got the trick?
> colors?
What kind of RLE encoded source do you have? Is this just for simulation
with a file as input and output or is it for real hardware?
BTW: all in all it is definitely a problem a beginner can solve by
doing some brainstroming. If you have a lack in information, why don't
you ask your professor? Maybe he's waiting until the first one asks for
the missing infornation of the RLE encoding structure.
Guest #6318532
• ▲ useful
▼ not useful
Hi Lothar .
Thank you for the great explanation.
I got your point . Theoretically it's easy to understand .
We have a 4bitmap image . I checked the Bitmap file format in Wikepedia
and it turns out that a 4 bitmap is identified by BI_RLE4 (which is Run
length encoding)  It would have been atleast easier if it was 24bitmap
image (RGB)
>Is this just for simulation with a file as input and output?
Yes
Literally nothing . We have to learn everything by ourselves this
semester . He said that it's a challenge for us during this coronavirus
situation to learn this topic alone .
The problem right now is how to identify the colors ? Is there like for
each color a defined 4 bit value ?
Guest #6318917
• ▲ useful
▼ not useful
> image (RGB)
OK, this is the Microsoft bitmap format. The first thing you have to
understand is, that this special subformat is an indiced format. That
means, the content of the bitmap are not color values, but indices into
a color table.
You've to look into the color table. What else?
Guest #6319213
• ▲ useful
▼ not useful
MaWin wrote
> The excercise only calls to swap 2 colors, not which ones.
Actually I want to swap 2 specified colors not any two colors .
So can I use this color table as a source ?
It says: Blue is =  0001
         Green is = 0010
         Red is =   0100
Guest #6319224
• ▲ useful
▼ not useful
MaWin appearently misunderstood the intention (might be: wanted to
misunderstand to expose your stupid, incomplete specs)...
>          Green is = 0010
>          Red is =   0100
Yes. Exactly this is the sense of a color table. Save memory. Store 4
bits only in the bitmap instead of 24 (or 32).
Guest #6319569
• ▲ useful
▼ not useful
Leonardo wrote:
> Thank you @ c-hater : One last thing to ask :
> How do I get the width and the height of a bmp image using VHDL ?
> I don't want to write constant values .
You've to extract it from the bitmap info header of course. Even you've
to extract the existence(!) of a color table and the color table
itselves, as long it exists in the file...
Keep in mind: the color table isn't mandatory. In the case of it's
absence you've to use a "default" (VGA).
That's for very historical reasons...
In the case of existence you've at least to check the number of entries.
It should be sufficient to cover all appearing indices in the bitmap
by standard. But you shouldn't trust foreign data at any time...
Guest #6319754
• ▲ useful
▼ not useful
MaWin wrote:
> There ist no need to know width and height if all you have to do is swap
> 2 colors.
Of course he must know this. At least under the given precondition of an
RLE-encoded bitmap...
Are you stoned or are you not the actual MaWin? I assume the latter...
Guest #6319974
• ▲ useful
▼ not useful
I know but still I'm totally new to image processing thus every details
will count .I have a small knowledge on VHDL so this will be a challenge
for me .
I actually code most of the time with C and C++ and I'm familiar with
solving problems .
Logically speaking if I want to have this kind of matrix in my image in
C/C++
I would read everyline at once and then analyze their colors and swap
the two colors that I want to swap  .(In this case I won't need the
image_width and height like you said)
In C for example it will be something like this (but still I don't know
if it works on bmp image )
Char Zeile[101]= {'\0'};;
FILE *Datei = fopen("image.bmp", "r"); //Read modus
 while (fscanf(Datei, " %101[^\n]", Zeile) == 1)
 // Analyse the file and swap the colors of this line
 or I make a whole matrix with this file and then swap later ..
Something like that : it will read everyline of the bitmap image till
the end of file (EOF).
Should I follow the same logic on VHDL ?
If yes then I would really appreciate it if you write me some code in
VHDL how to scanline the image till the EOF.
Guest #6319984
• ▲ useful
▼ not useful
foobar wrote:
> Two swap two colors in an indexed image you just have to swap the
> correpsonding entries in the color map - there's no need to process the
> image pixels at all.
Could you please write me a little example with vhdl how can you swap 2
entries colors WITH RLE . It would help me a lot to understand how it's
working exactly.
Guest #6319988
• ▲ useful
▼ not useful
First: Parsing BMP-Files in VHDL sounds kind of silly - are you sure you
got your task right?
Second: As I said, no need to parse the RLE, just swap two entries in
the palette.
Third: It's your job - you'd learn nothing if I'd do it for you.
Fourth: I would implement a simple CPU (like J1) and write a program for
it ;-)
Guest #6320035
• ▲ useful
▼ not useful
> solving problems .
Then solve it in C/C++ first.  That way you don't have to deal with two
problems, the algorithm and the new language.  When the C version is
done, you have the algorithm and know what to do and can now concentrate
on how to do it in VHDL.  Use a method that can be used in both
languages, i.e. a state machine.
Moderator (Company: Titel) #6320036
• ▲ useful
▼ not useful
Don't look at the internet, look on your own PC. Use YOUR specific
picture files to check it out. I think the professor supplied some or
gave a hint where to find them.
Leonardo wrote:
> I have a small knowledge on VHDL so this will be a challenge for me .
See it that way: this is NOT a VHDL problem at the first step. You
simply don't know about the structure of the files you must handle.
Leonardo wrote:
> I just wanted a little example to know how it works ..
1. For the first step: forget about VHDL (forget about programming at
all)
2. Take a HEX Editor
3. Open  YOUR specific picture file
4. Locate the color table in YOUR specific picture file
5. Find the two colors in the color table
6. Swap their values
7. Save the edited file
6. Check the result with a picture viewer
7. Finally, when the result is what you wanted, then think about how you
could use VHDL file commands to automize steps 2..7 and write the code
Having done that all you will see, that step 7. was the most easy in the
whole process.
Begin with 1.
Leonardo wrote:
> True It would've been so much better for me if it was in C/C++
Then solve that "open file - parse file - swap colors - save
file"-problem with C. And I mean that you solve it in a way that really
works. When you have it running in C, then you can fairly easy translate
it to VHDL by using similar commands, because the whole thing is just
for simulation.
> are you sure you got your task right?
I think, the professor just wants to teach some little file handling and
digging for data. And for that the task is nice, because you can
visualize the results very simple on any screen device.
> for me .
BTW: such punctuation marks like . and , and ? and etc. belong to the
words at the left of the symbol. It is very disturbing when you place a
space on the wrong side of such puntuation marks.
BTW2: Leonardo-Fernando, pls use only 1 user name in 1 thread. It is
very distracting to discuss with randomly named people!
Guest #6320858
• ▲ useful
▼ not useful
Thank you so much Lothar I'm getting so close to the solution .
I'm trying to use the ASCII codes of the colors right now but there's a
little problem that I will have at the end .
With my HEX EDITTOR I wanted to set the red to blue without swapping
them, just replacing and that's all .
But it seems that the red color will change differently : Red color
became black . I think that it mixed the red with blue color => Black .
Any solutions for that ?
#6321505
• ▲ useful
▼ not useful
Using the hex editor for my image is the
ASCI code for blue :..ÿ
ASCI code for my red :ý..
When I set every code that has "ý.." to "..ÿ" the colors have atleast
changed but not correctly .
I tried this while using vhdl code but nothing happened. The output
image stays the same as the input image .
If you wonder if the if statement is working or not . It's working! I
tested with the debugging report method .
Excuse me for the messy code.
Moderator (Company: Titel) #6321565
• ▲ useful
▼ not useful
Leonardo J. wrote:
> Using the hex editor for my image is the ASCI code for blue :..ÿ
A HEX editor shows HEX digits at first. And it may show ASCII chars
additionally. I use HxD for hex editing.
Leonardo J. wrote:
> the colors have atleast changed but not correctly .
Did you do such a swap manually as I already suggested?
No?
I did. And having a file finally it is an easy job to dig out what has
to happen. See your Color.bmp and compare it to the Color_sw.bmp. See
the difference and how it behaves. Now do the very similar change to the
file with VHDL.
Moderator (Company: Titel) #6322716
• ▲ useful
▼ not useful
Leonardo J. wrote:
> Just a quick question : Should the red color normally be FF 00 00 (00)
> and not 00 00 FF (00) (internet source)?
My internet source says that the bmp byte order is BB GG RR 00 in the
color lookup table:
https://de.wikipedia.org/wiki/Windows_Bitmap
Jeder Eintrag der Farbtabelle ist 4 Byte groß und enthält jeweils ein Byte
für den Blau-, Grün- und Rotanteil, sowie ein auf 0 gesetztes Byte (in dieser
Reihenfolge!).
The very same can be found there:
https://en.wikipedia.org/wiki/BMP_file_format
In most cases, each entry in the color table occupies 4 bytes,
in the order blue, green, red, 0x00 (see below for exceptions).
> (internet source)?
Which one did you use?
Leonardo wrote:
> Maybe some students from my class can see the answer .
Whats the problem with that (beside its bug)?
Maybe it helps your classmates like I helped you. From my view that
would be nice...
#6322822
• ▲ useful
▼ not useful
> color lookup table:
> [pre]
> Byte
> dieser
> Reihenfolge!).
Thank you Lothar, I actually didn't know that . I thought that the color
order is always the same. (RGB)
> (internet source)?
I just checked a random source : https://www.color-hex.com/ .
That's why I got a little bit confused .
> would be nice...
Yea sure thanks again .
Have a nice day .
Moderator (Company: Titel) #6322865
• ▲ useful
▼ not useful
This is correct for the usual way with RRGGBB as used in most
programming languages.
And now, if you want to fit that in a 32 bit integer, you may add some
00 in front of those 24 bit: 00RRGGBB. And if you give those 4 bytes in
that 32 bit value an address you can write it that way:
 3  2  1  0
00 RR GG BB
This because the leftmost byte represents the highest integer value and
therefore it gets the highest index.
And now when you write that values in the order of the bytes in a file
and view at it as in my hex editor screenshot ascending from the left it
looks like that:
 0  1  2  3
BB GG RR 00
Do you recognize that very pattern?
What we learned here: never believe nobody anything. At least until you
can follow his/hers thoughts.
#6323162
• ▲ useful
▼ not useful
I see, thanks for the explanation . I didn't think that it was this
easy.
Maybe I will make program for all the cases together (4bpp, 8bpp, 24bpp
and 32bpp). It would be better .
  • [vhdl]VHDL-Code[/vhdl]
