Free workshop materials: Integrating ARM Cortex M Processors into Xilinx FPGAs
OP (Company: Digilent Inc) #6315711
The workshop materials include 3 hands-on labs. By completing these
labs, you can
1. Explore the ARM Architecture in Xilinx Vivado
2. Understand the flow to implement Arm Cortex-M processors in on
Spartan 7
3. Use the Xilinx Vivado Design Suite, and drag-and-drop ARM Cortex-M3
soft IP on Spartan 7
4. Create a simple environmental monitoring application
Link:
https://digilent.s3-us-west-2.amazonaws.com/resources/programmable-logic/arty-s7/Integrating%2BArm%2BM1%2Binto%2BXilinx%2BFPGAs_Workbook.pdf?_ga=2.161529662.345283832.1591980418-123638491.1591980418
(Company: Home)
 For my opinion, it's two application for using ARM (or other processor)
built in inside FPGA :
First  : you have not place on the board for external processor.
 Second : you have high speed bus such as video bus benween processor
and FPGA.
 For other application preffered external standard processor.
 Regards Alex.
Guest
any more information you could give about it?
- Is the HDL opensource?
- If not, is it bound to specific device/toolversion?
- Can it be used in simulation?
- What clock rates are achievable with the Spartan 7?
- Ressource usage?
- can user instructions be added to the cpu?
- which versions of the ARM are available? You write M3 here, but
tutorial seems to use M1?
Some information about the IP core can be found on the ARM website:
https://www.arm.com/resources/designstart/designstart-fpga
No, but it seems that it is royality free. Quote: "just a simple
agreement", didn't found much more.
Xilinx Vivado and GoWin.
> - Ressource usage?
I don't know. Good questions.
M1 and M3
Yes. I think so.
https://developer.arm.com/docs/101483/0000/working-with-the-cortex-m3-designstart-example-design/simulation
I think you can check when you open the core in Vivado. That is what you
are doing in Lab 1.
> - Resource usage?
Check the ARM Cortex M3 guide
Check the ARM Cortex M3 guide.
Guide for ARM Cortex M1:
https://developer.arm.com/docs/100211/0000?_ga=2.2970992.1916686665.1593105448-1209826936.1593105448
Guide for ARM Cortex M3:
https://developer.arm.com/docs/101483/latest/preface?_ga=2.2970992.1916686665.1593105448-1209826936.1593105448
Getting Started with ARM Cortex M: https://youtu.be/kSaQJGSu-yI
How to use an Arm Cortex-M processor with Xilinx-based FPGAs and SoCs:
Recording request at
https://event.on24.com/eventRegistration/EventLobbyServlet?target=reg20.jsp&partnerref=web&eventid=1919340&sessionid=1&key=2D3AD9860439205A995DD673F19BC0DC&regTag=&sourcepage=register
Other resources link:
https://community.arm.com/innovation/b/blog/posts/arm-innovator-adam-taylor-shares-top-20-resources-for-fpga-developers
Guest
Thanks for all the links, will check them out.
That a simulation model exists is great, even if it's very restricted
with specific version of the core because of security.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
