Determining signal
OP (Company: None) #6303516
• ▲ useful
▼ not useful
I wish to monitor two signals and I wish to determine which of the two
changed first and then do some work accordingly.
 module tb(input sel1,
                 input sel2);
//Determine which of the two changed first
if sel1 changed first :
     //Do some work
else :
     //Do some Other work'
endmodule
The above is a sample code. I have also attached a photo as an example.
In the  photo, in the first instance sel1 changed first and the 2nd
time, sel2 changed first, (NOTE : going from low to high is a change,
according to the picture)
Can someone help me write a code which can help me to make out which of
the signal changed first.
Thank you
Guest #6303529
• ▲ useful
▼ not useful
No, thats not code, it's just a useless snippet.
Also the module is useless, because it's missing any output,
Also a clock signal is missed, I would not start to design with latches
because this is bad design practice.
OP (Company: None) #6303571
• ▲ useful
▼ not useful
No, that code is not useless. There need not be any output in a module
sometimes. I shall write a more specific code now.
          input sel2,
          input hsel,
          input data,
          input addr);
integer fd;
initial
begin
fd= $fopen(fd,"w");
@(posedge hsel)
// Determining which of the inputs changed first
// if sel1 changed first
  $fwrite(fd,data);
else
   $fwrite(fd,addr);
$fclode(fd)
end
endmodule
The input is coming from a testing system which is put under
verification.
Basically a design has been put under verification and it outputs some
data which is being fed to this module and I need to record the output
of the system under verification.
  • [vhdl]VHDL-Code[/vhdl]
