Search for best processor long term data logging
Guest #6300639
I am not sure how to search to not trigger the same processor which I
thought might be the best. Goal is logging temperature, brightness and
clarity of lake water.
So my requirements are:
1 year logging
3 analog Input ports
USB connection
I calculate about 250kB-500kB for 1 year (e.g. 1 measurement / 4h).
AND I would need to use a small battery pack only (could be 500mAh 9V
Block or 3.3V Li Cells)
Ideally to read out the data SD card seems to be favorable too. But
higher requirement is the battery limitation.
So I was thinking of ATtiny85 or Arduino Nano kind of setup with some
extra storage connected. But I may be wrong.
So any help is welcome. If there is such project somewhere to find even
better. :-)
best regards
Dirk
(Company: privat)
Hi Hinz, thanks for feedback. There seem to be compatibilities with
Arduino boards, I have to find out. On TI page it says GCC compiler that
should be ok. I have not yet much found on eval boards. In the end I
like to build about 15-20 applications so have to look at price finally
too.
Let me check this out tomorrow.
Best regards Dirk
Guest
> of setup with some extra storage connected.
Aduino Nano is not a good idea because of it's USB-interface. In this
case, the A* ProMini is a good choice, sleep with timer around 5µA:
http://www.home-automation-community.com/arduino-low-power-how-to-run-atmega328p-for-a-year-on-coin-cell-battery/
If you use the version with 8 MHz, it can run directly from one
LiIon-Cell.
However, you need to think about powering of your sensors, can work
between 4.2 and 3.0 Volt? How to powering down while the AT328 is in
sleep mode?
How you can handle powering down your sd-card and initialize again after
restart? The usual China modules have an xx1117-3V3 with too mouch
quiescent current, replace by MCP1702 / 1703 but with different pinout.
Guest
Hi Dirk,
do you really want to fire and forget?
I could imagine it is quite unpleasant if you leave the hardware at the
lake and the firmare/hardware does weird things - for whatever reasons.
And of course do you want to collect data in shorter periods than one
year? What if a sensor runs away or gets broken?
I'd suggest to use some rf magic like Lora (if monitoring is a thing),
also you should have a not too bad time reference - you could of course
use the ambient light which is accurate for longer periods but why so
complicated ;)
A external RTC is quite accurate and not to expensive.
For the MCU selection - if you want to stick to Atmel/Microchip go check
the tiny816 or the amtega 0 series (eg. Atmega3208) those are quite
decent IMO.
If you want to have low power the EFM32 claim to be very low power.
If you're concerned about power consumption and don't mind larger
footprint, use a solar cell both as light sensor and energy source (or a
solar cell as energy source and an off the shelf ALS if you don't want
to bother calibration)
Just some thoughts :)
Guest
you somehow lost me on bightness and clarity already ...
sounds like one and the same;
or you want to measure the tint and opacity?
Anyhow, that sounds like a more sophisticated optical sensing than a
good ol' photoresistor.
More like a full fledged albeit low res camera module.
I'm only asking because that will (well - might) be the main cause for a
drained battery;
and as that it's almost of no importance if you throw an ATTiny10 or an
ATMega16 at it.
In terms of reliability I guess any modern day µC that has a wide enough
temperature range for your lake in question will do just nicely.
So the only thing I can think of is low power consumption.
So in order to answer the question in a reliable way, it'd be important
if you could let us know what three sensors you have in mind.
(make and model and if possible linked datasheets)
To properly guess the required amount of battery juice for a single
reading and then expraopolate from there.
Too bad btw you said lake not river...
I saw a hobbyist project once that used a tethered submarine-style
controller with a tiny turbine..
the flow charged an array of caps which then powered the gear.
that was nice.. (IIRC it was only temperature and time to interpolate
flowrate or such.. can't remember exactly.. hence I cannot find it atm)
Another possibility might be to equip the gear with a small solar cell,
salvaged from an ikea garden light or such..
(I think there are also swimming pool lights that work alike)
a small amount of rechargeable double-A batteries (mostly just one,
sometimes up to three) power those lights,
and usually should hold enough of a charge to power your gear for quite
a while.. if it's enough to cover all of a long winter IDK,
depends on the requirements again.
'sid
(Company: privat)
@ Sid: Yes, 3 sensors is my plan:
1xTemperatur - resistor
1xPhotodiode or resistor
1xOpacity:
https://www.ebay.de/i/362675061100?chn=ps&norover=1&mkevt=1&mkrid=707-134425-41852-0&mkcid=2&itemid=362675061100&targetid=896427593016&device=c&mktype=pla&googleloc=9044506&poi=&campaignid=10199424628&mkgroupid=101937413997&rlsatarget=pla-896427593016&abcId=1145992&merchantid=7364532&gclid=CjwKCAjw8pH3BRAXEiwA1pvMsejQ9R8-5p2zAebk_C2zt75AhV0Hf7CxIKgTiOgXtQw1nMKJVd-GIhoCuxgQAvD_BwE
I have thought on a solar cell at the water surface as well but the
problem is that other people see the solar cell and will remove it.
Therefore I need to mount it below water surface in 1xsensor pack at
0.1m, 1 at 5m and 1 at 10m. So that will be in total 3x3sensor packs. I
intended to keep them independant due to robustness so they can easily
connected to a simple rope.
Does this help to understand?
Best regards
Dirk
Guest
Dirk B. wrote:
> 1xOpacity:
That part alone needs 11mA during Operation.  Did you calculated the
total power requirements of all sensors during the your campaign?
Methink processor power is neglectable.
Btw. 10 meter depht means 1 bar pressure (1kg on each cm²). On a first
view i do not see how you can tighten this sensor against it (i made
measurements much more deeper and offshore).
Putting sensors in natural waters invites all the tiny little creatures
in fouling and covering your sensors. Are you aware of this? Then you
have leakage out from moisture. It is hard to tighten a case over longer
periods without special hardware. Putting ebay buying parts together in
a case means  a hard way to prevent this.
(Company: privat)
@Toby, yes I am aware of the sealing topic. I have been building an
underwater lamp for scuba diving. I would be able to view the sensor
from frequently but I do not want to need to do so. We will be cleaning
the sensor from algae if necessary as well. The sensors we be mounted on
the side not at the top. My plan currently. I wanted to prepare "diver
eggs" for it. - Regards Dirk
Guest
So nine sensors, not threee all of a sudden then..
and lacking the info on what sensors will be involved but one
(an ebay link is not a datasheet..)
If that's your type of research, I'm afraid I don't bother too much...
The footwork at least should be your part not ours!
good luck with the project.
'sid
(Company: privat)
@Manfred, yes I agree the sleep modes are very important to get
realized. Therefore I like to use a µC with those capabilities.
The article on powering down the AT ProMini I like very much. That
allows working on a well-known platform and step-wise powering down the
setup.
So the USB-Board you probably have then remotely for programming only -
I guess. Would you recommend a DTR connection as well? Due to sensor I
would choose the 5V variant knowing now that this will be even better.
I guess that the sensors in sleep will be fully depowered and do not
create additional currents?!
Then to the 13mA I problably have to add 11mA for opacity and let´s be
safe 10mA for Temp. and Photoresistors each. So it would be 44mA total.
What about the data storage now? The A*Nano offers sufficient storage.
So with realization of Pro Mini: To connect the SD card you said replace
China-ware with low power chip variants of MCP1702/3. SD Card then could
be filled with MBytes? As said 1MB will be enough.
SD card consumption? I read 100mA for 5ms, so with a wake-up cycle and
writing at the end the overall energy shall be low. In stand-by I saw
values around 250µA. Powered down does it get depowered further down or
do I require MosFET switches or so?
Any comments welcome. Many thanks to all for helping to frame it. - Dirk
(Company: privat)
.. furthermore: I need to log date/time as well. Do I need the Crystal
version of an A* ProMini? or is the runnaway neglectiable: some
10minutes are no problem in a month I would say.
(Company: privat)
@sid, sorry 3 different sensors to add in one project as said above. I
do not get more information so far on the turbidity sensor. The other 2
are a thermal resistor and a photoresistor (or photodiode). But I plan
to have 3x the same setup built. Due to seaing topics I will not couple
them. There is much more expensive turbidity sensors 200-5000 Euro
though. I have seen other sensors where I have asked for quotes and data
sheets. This is all I was able to investigate in the short time. But
never mind. If the turbidity sensor turns out to be a bad one I may have
to skip that one unfortunately or I find another in the mean time. I
know that turbidity is not easy to measure.
Thanks for your comments . take care.
Rgds Dirk
Guest
okay for time_based logging;
@Dirk you didn't understand..
the exact sensor is important to get it's demand and respnse time
properly.
"some photoresistor" is just not going to cut that.
Anyhow, you'll need to cover that battery reqquirement on your own once
you get the infos yourself then.
Timely based logging:
No problem, just don't :D
Honestly, since you log in consecutive order (write storage in
consecutive bytes) and you know the length of each dataset;
you can calculate the time of each entry with your reader later on and
save a significant amount of storage
(say each set has 20 bytes) so the 400-420 block is the 20th reading and
with one reading every 4hrs it came in 80 hours after it's initial
start.
(simple math easily to be done even in a simple spreadsheet excel like
reading application)
In order to get the most accurate times, a RTC would come in handy..
most require a significant amount of juice unfortunately or get quite
expensive easily.
So what I've seen to work well is a cheap LCD Quartz watch with an alarm
function acting as a trigger.
it itself is powered by it's own tiny button cell (as usual)
with an alarm set every four hours.
the buzzer is replaced with a signal line to trigger the powerboard.
And the "alarm off" button is connected to a datapin on the arduino.
When the alarm goes off the powerboard then sends the 5V (or what have
you) to the arduino,
which in turn holds the powerboard active and reports the "I'm awake
stop beeping" buttonpress to the watch (to stop the alarm).
Once the arduino has done it's work and logged all data properly
it cuts it's own powerline to the powerboard which in turn then falls
back to sleep automatically and neither the arduino nor it's attached
sensors get any power.
So all you need is a low standby current powerboard, which should be
fairly easy be done in <7µA or such..
IDK if there are any prefabbed chinese ones out there (I guess so) but
plans on how to make one are widely spread over the internet.
(the infamous amazon order buttons used a very similar power-approach
for example powering a wifi reporter with a single triple A over several
thousand button presses)
And best of all the arduino's watchdog doesn't need to wake up every
couple of seconds to count up to the four hours, but it just hangs there
waiting for the alarm to tickle it'S power switch.
So all idle power is part of the cheap wristwatch movement.
even the lousiest LCD watches can last well over a year from those tiny
button cells..
and if you worry about that,
you can just replace the buttoncell with a triple A to have it last for
decades if you want.
'sid
(Company: privat)
@bananenbieger - Yes, I am aware of the problem. We will be able to
clean regularly - almost weekly but do not want to remove and readout
all the time.
@Diver - The CavePearlProject and ESA Article are good input also using
Arduino ProMini. Triggers ideas to isolate the sensors better in the two
parts I have anyway with the diver´s egg.
@Sid - great input: 1. to use a separate watch to wake-up the board. It
generates also more freedom with the sensors if needed to exchange. This
is best input now and solves most of the problems on power!!!
2. to not log the date/time information. That reduces the storage down
to ~34kByte for 1h logging and ~8kB for 4-hourly logging: Then it could
already match into the Flash, but readout might be less comfortable than
with SD cards. I wanted to mark them and can other people also to
transport them. But with first approach it doesn´t matter too much
anymore.
to the sensor topic: All 3 sensors would provide analog signals which I
hope the Arduino resolution is sufficient to resolve. Specifcation says
10bits which is each 1024 values for Temperature, Brightness and
Turbidity. If I look at the tolerance of the sensor of 5% e.g. I do not
need to store that many bits. 2 byte for temperature allows 0.5° in the
range I need. and 1 byte each for brightness (sunny days vs. milky days
+ turbidity) and turbidity (4.4 NTU would provide the 10 bit resolution
- according to the data provided on the website - and the relevant area
will be between 0.2 to 50 NTU max. => 4 bit sufficient =>1byte). 4 Bytes
in total per log only!
I will go shopping now for the parts :-)
Many Thanks & Regards Dirk
Guest
An RTC perhaps a DS1302 or so takes far less current than anything self
built. in the order of 400nA or less. There are RTCs which can provide a
timer interrupt eg for wakeung up a controller.
(Company: privat)
Hi guys,
still searching for a useful clock which provides continues alarms like
a programmable timer. The DS3231 has two alarms which on the one side it
says "Two programmable time-of-day alarms". Does this mean 2 times per
day only? I need to be able to get to e.g. each 1h or 2h or so.
On the other side the data sheet shows a table of timekeeping registers:
There is function column saying "alarm 2 minutes, alarm 2 hours, alarm
1h, ...".
Table2: ALarm Mask Bits: There it says ALARM RATE: Alarm when hours
match. So it looks that it should work. But I am unclear whether only
full time need to be set und therefore just one single time / day is the
trigger finally?
"Alarms The DS3231 contains two time-of-day/date alarms. Alarm 1 can be
set by writing to registers 07h to 0Ah. Alarm 2 can be set by writing to
registers 0Bh to 0Dh. The alarms can be programmed (by the alarm enable
and INTCN bits of the control register) to activate the INT/SQW output
on an alarm match condition. "
I just don´t want to buy wrong device and wait another week or so to
continue..
Many thanks for quick clarification: Does this 1h hour timer work with
DS3231?
Dirk
Guest
Dirk B. wrote:
> We will be cleaning
And reading the data during inspection is not an option?
> all the time.
Why? you can replace an external battery and SD card (and hold a backup
in the probe).
(Company: privat)
@Toby,
Well I do not want to open the box sealing regularly. The sealing will
suffer too much and finally the electronics gets watered. :-(
The sensors I will put into Epoxy resin to isolate from internal
electronics. The outside is the one which can be easily cleaned.
Dirk
p.s. any idea on the clock timer?
Guest
> anymore.
This sounds to me that you plan to use the program flash of an ATMega328
as data storage. Do you have some experience in doing that? It's
possible but not a simple task.
If you do not want to use SD cards, why not just taking a separate SPI
EEPROM to store the data. If you get a PDIP package and put it in a
socket, you can just take it out and read the data externally.
Guest
> Dirk
Maybe a 2 part design with watertight connections makes sense. One with
sensors and one with battery and memory. Than you can use enough power
and gets rid of 1 year storage demand (and risks like data loss by
device loss).
Doing this and long term storage and sensor operation demands are an
option and nice to have.
Me think there are conflicting design goals. A very low power very
special device made out of standard components. Designing that way runs
often in unforeseen conditions that are hard to handle, lacks
flexibility and ends in extensive component search.
Sorry no, i will made the whole project with an XLP PIC. Simply because
i can. Last time i had sleep current below 100nA. Due to periodic wake
up the clock timer is always included (or complimentary).
Guest
I am in implementation phase. I have got a problem not yet solved with
the alarm output from a DS3231 ZS-042 module: The alarm does not switch
the SQW port. Now I am reading adverse information on removing
resistances (there is a 4xCascade pullups or not.
PIN2 of Arduino mini can be switched an is set to HIGH as default.
Output of DS3231 stays at LOW. According to data sheet it says that
output requires an external pullup resistor which I would say is the
cascade. But stays on LOW. IT evens pulls down the Interrupt pin2 of the
Arduino board. What´s wrong? THe clock generally works and gives out
TIME, ...
I have used several implementation sketches.
So first question what to do with these resistance cascade?
Thks
Start a new thread
