VHDL Generic Bus I/O MUX
Guest #6303120
You published pretty lot of files today, but a closer look shows, most
of them are simple and some even faulty and crappy. This is not standard
code quality.
OP (Company: Home) #6303884
>most of them
>are simple
 Yes, these are "stones" for my large projects.
>and some even faulty and crappy. This is not standard code quality.
 You can explain that to all and I'll try to repair it ... I will say
you thanx.
 Regards alex.
Moderator (Company: Titel) #6303958
Alexander S. wrote:
> Attached ModelSim VHDL design of Generic Bus I/O MUX.
I don't understand what the whole thing is good for. A tristate buffer
usually needs not more than two lines.
A few words to that code:
InOutProcess:
process (ClockIn,nEnableIn)
begin
 if nEnableIn = '0' then
  DataIO      <= DataIn;
 else
  DataIO     <= (others => 'Z');
 end if;
 if ClockIn'event and ClockIn = '1'then
  case nResetIn is
  when '0' => DataOutValid <= '0'; -- Data for trnsport from DataIO to FPGA valid
              DataOut <= (others => '0');
  when others =>
              DataOutValid <= nEnableIn; -- Data for trnsport from DataIO to FPGA valid
              DataOut   <= DataIO;
  end case;
 end if;
end process InOutProcess;
Never ever use combinatorial and synchronous descriptions in the same
process!
Additionally the simulation will be wrong due to the missing "DataIn" in
the sensitivity list.
OP (Company: Home) #6304082
> process!
 You are right :
library ieee;
use ieee.std_logic_1164.all;
entity InOutGen is
GENERIC (DataRange  : integer);
port
  ClockIn,        -- General Clock
  nResetIn,        -- General Reset active low
  nEnableIn      : in    std_logic;                                              -- Active 0 for read from FPGA
  DataIn         : in    std_logic_vector(DataRange downto 0);                   -- Data for trnsport from FPGA to DataIO
  DataOutValid  : out   std_logic;                                               -- Data for trnsport from DataIO to FPGA valid
  DataOut        : out   std_logic_vector(DataRange downto 0);                   -- Data for trnsport from DataIO to FPGA
  DataIO         : inout std_logic_vector(DataRange downto 0)                    -- External Data Bus
end InOutGen;
architecture ArchInOutGen of InOutGen is
begin
OutProcess:
process (nEnableIn)
begin
  DataIO      <= DataIn;
 else
 end if;
30
end process OutProcess;
31
32
InProcess:
33
process (ClockIn)
34
begin
35
36
  case nResetIn is
37
   when '0' =>
38
    DataOutValid <='0';                                                         -- Data for trnsport from DataIO to FPGA valid
39
40
    when others =>
41
42
    DataOut       <= DataIO;
43
  end case;
44
 end if;
45
end process InProcess;
 Thank you for good cooperation.
 Regards Alex.
Moderator (Company: Titel) #6304100
Alexander S. wrote:
 OutProcess:
 process (nEnableIn)
 begin
   DataIO      <= DataIn;
  else
  end if;
As already said: the simulation doesn't fit reality due to an incomplete
sensitivity list. DataIn is missing.
All in all this process is just bloating code. It can be replaced by 1
concurrent line of code:
 DataIO <= DataIn when nEnableIn='0' else (others => 'Z');
OP (Company: Home) #6304120
 Thanx.
OutProcess:
process (nEnableIn,DataIn)
begin
  DataIO      <= DataIn;
 else
 end if;
 Usually, I use synchronous only process which have only clock in the
sensitivity list.
 Regards Alex.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
