VHDL Generic Counter with Clocked Rise OutPut
Moderator (Company: Titel) #6301043
Alexander S. wrote:
> design of Generic Counter with Clocked Rise OutPut.
All in all I see a very laborious way to generate a clock enable. Whats
the advantage prior to a simple counter?
One word to this:
GENERIC (DivideRange  : integer);
signal ClockDivider, DividerFactor : integer range 0 to DivideRange;
begin
       DividerFactor <= DivideRange - 1;
       ClockDivider <= ClockDivider + 1 mod DividerFactor;
As "mod" implements a divider, this design will lead to extensive logic
with some values for "DivideRange". Because only values in (2**x+1) will
be easily synthesizable.
OP (Company: Home) #6301102
https://www.ics.uci.edu/~jmoorkan/vhdlref/vhdl_golden_reference_guide.pdf
The
VHDL
Golden
Reference
Guide
Page 80 :
Operator
Synthesis
 The operators / mod ... ** are not synthesizable
 Regards Alex.
Guest #6302147
That's not true, at least not in all cases. Nor it is limited to trivial
cases (eg. 2^n). I used it a few times.
The statement may be correct in 1995, but not nowadays.
greeting
Moderator (Company: Titel) #6302161
Of  course x/(2**n) is synthesizable, because it's only some rewiring.
E.g. for x/4 just the lowest 2 bits are skipped.
And when a division is synthesizable, then "mod" is also, because that's
only to ignore the upper bits.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
