reading BH1750 lightsensor with Atmega328P using i2c /TWI
Guest #6288830
currently i am trying to connect a BH1750 lightsensor with i2C/TWI to my
ATmega328P (Arduino uno but i dont use the arduino interface). After 3
days of failure i decided to get some help.
I dont know if my code is wrong or my hardware wiring. i attached the
main.c which contains all the code i use to test it. I also attached a
fritzing picture of the wiring.
currently i have the following working:
- i set the start condition for i2c
- i send the slave address (TWDR = SLA_W which is 0x5C)
- i specify the register i want to read (TWDR = 0x10 based on BH1750
Datasheet in which operation code for recommended mode is 0001_0000)
- i switch master to read by sending another start signal and setting
TWDR = SLA_R (0x5D)
- Now i want to read the message from BH1750 so i set TWCR as usual but
this time with ACK (acknowledge)
- And now i am stuck i wait for completion as i did after each operation
using: while(!(TWCR & (1<<TWINT))); but the while never ends.
i would expect to get the first data byte now which hopefully is the
first part of some lumen value. In Total i expect 2 bytes of date
because the sensor resolution is 1-65535 lx.
I know my code is not flawless but for now i just want the. connection
to work (I miss stuff like status checks and first part of communication
should also use ACK,..)
If anyone has an idea what the problem could be please tell me because
at the moment i am clueless.
greetings
Sebastian
BH1750 Datasheet:
https://components101.com/sites/default/files/component_datasheet/BH1750.pdf
Atmega328P Datasheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-7810-Automotive-Microcontrollers-ATmega328P_Datasheet.pdf
(i2C starts at page 174)
Guest
leo wrote:
> Sebastian wrote:
>> #define I2C_WRITE 0;
> All these semicolons in defines are plain wrong.
> leo
removed them but i doubt it made a difference couldnt see any
Guest
Yes, it did work by chance. Though I didn't look further as you have
likely more C-related errors in the code. And yes ...
>   TWBR = ((16000000 / 100000) -16) / 2;
That may overflow. Compare to the F_CPU define.
leo
Guest
Don´t know this Sensor, but it seems to be the wrong Address.
Low - 0x23
High - 0x5C
Simply try to change the Code from
uint8_t SLA_W = 0x5C; // Address from slave + write (which is +0) // 0x5c because i found it in the Internet not in data sheet.
to
uint8_t SLA_W = 0x23; // Address from slave + write (which is +0) // 0x5c because i found it in the Internet not in data sheet.
Guest
I tryd both with 0x5C i get to the following point:
start condition
send address
specify register
read first message
waiting for completion of read...
with 0x23 i get the following:
start condition
send address
specify register
but you are right it should be 0x23 because i connected ADDR pin to
ground at least thats something i read. Maybe the register 0x10
Guest
[SOLVED]
Ok i got it working now. The major issue was that the address i used was
wrong. The solution was basically at Page 7 of the BH1750 datasheet.
There i found an example with address bites that worked.
I also added ACK accordingly and some status checking for debugging.
And i completely removed the ADDR wiring so the ADDR Pin of the BH1750
has now no connection at all.
I attached the working code as LightSensorRead.c .
thanks for the comments.
(Company: no)
Hello Sebastian,
Have you got the BH1750 working properly ? I also want to get this
device work in non arduino interface. I am writing it in Atmel studio .
But i cannot get it works .
Can you or any one share experiacne or code for this ?
thank you !
Tommy
Start a new thread
