Stopwatch in VHDL
Guest #6274594
Offcourse, Sure, freilich, if you can draw a state diagram at least in
your mind. With the right hardware this precision is also possible.
But a cheap microcontroller would also fit the task.
Guest #6274927
If you don't have a Städte concept in your mind then draw one first.
What are the inputs and outputs?
And then write the neccessary logic.
Guest #6275012
Guest #6299462
I wrote this...
What do you think?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity Stoper is
port(  CLK, onOFF, memPUSH, reset : in STD_LOGIC;
    sec, min, hour, mem1s, mem1m, mem1h  : out STD_LOGIC_VECTOR(5 downto 0) := "000000";
    mem2s, mem2m, mem2h, mem3s, mem3m, mem3h : out STD_LOGIC_VECTOR(5 downto 0) := "000000");
end Stoper;
architecture Behavioral of Stoper is
signal S : STD_LOGIC_VECTOR(5 downto 0) := "111000";
signal M, H, P1S, P1M, P1H : STD_LOGIC_VECTOR(5 downto 0) := "000000";
signal P2S, P2M, P2H, P3S, P3M, P3H : STD_LOGIC_VECTOR(5 downto 0) := "000000";
signal stan : STD_LOGIC := '0';
signal memS : STD_LOGIC_VECTOR(1 downto 0) := "00";
begin
  process(onOFF)
  begin
    if (onOFF'event and onOFF = '1') then
      stan <= not stan;
    end if;
  end process;
  process(memPUSH, reset)
  begin
    if (memPUSH'event and memPUSH = '1' and memS = "00") then
        P1S <= S;
        P1M <= M;
30
        P1H <= H;
31
        memS <= "01";
32
    end if;
33
34
    if (memPUSH'event and memPUSH = '1' and memS = "01") then
35
        P2S <= S;
36
        P2M <= M;
37
        P2H <= H;
38
        memS <= "11";
39
    end if;
40
41
    if (memPUSH'event and memPUSH = '1' and memS = "11") then
42
        P3S <= S;
43
        P3M <= M;
44
        P3H <= H;
45
        memS <= "00";
46
    end if;
47
48
    if (reset > '0') then
49
        P1S <= "000000";
50
        P1M <= "000000";
51
        P1H <= "000000";
52
        P2S <= "000000";
53
        P2M <= "000000";
54
        P2H <= "000000";
55
        P3S <= "000000";
56
        P3M <= "000000";
57
        P3H <= "000000";
58
        memS <= "11";
59
    end if;
60
  end process;
61
62
  process(CLK, stan, reset)
63
  begin
64
    if(stan = '1') then
65
      if (clk'event and clk = '1') then
66
        S <= S + 1;
67
      end if;
68
69
      if (S = "111011") then
70
        M <= M + 1;
71
        S <= "000000";
72
73
        if (M = "111011") then
74
        H <= H + 1;
75
        M <= "000000";
76
        end if;
77
      end if;
78
79
    end if;
80
81
82
      S <= "000000";
83
      M <= "000000";
84
      H <= "000000";
85
    end if;
86
  end process;
87
88
  sec <= S;
89
  min <= M;
90
  hour <= H;
91
  mem1s <= P1S;
92
  mem1m <= P1M;
93
  mem1h <= P1H;
94
  mem2s <= P2S;
95
  mem2m <= P2M;
96
  mem2h <= P2H;
97
  mem3s <= P3S;
98
  mem3m <= P3M;
99
  mem3h <= P3H;
100
101
end Behavioral;
#6300001
Andrew wrote:
> process(onOFF)
>   begin
>       stan <= not stan;
>     end if;
>   end process;
Is this code only for simulation? You will have troubles synthesizing
this part.
Andrew wrote:
> if(stan = '1') then
>         S <= S + 1;
>       end if;
Are you really sure that you want to have a gated clock? What device are
you targeting, does it support gated clocks? Some FPGAs support it but
not all.
Moderator (Company: Titel) #6300208
Luckily it's not leading to a gated clock, but it is a very strange and
obfuscating way to write a clock enable.
See sel3 there:
http://www.lothar-miller.de/s9y/categories/6-Clock-Enable
Andrew wrote:
> What do you think?
Way to much clocks in that design. Each 'event acts like a clock source
for flipflops. Thats no good design practice.
The proper way to generate clocks inside an FPGA is by using the clock
managers.
And a usual beginners design has only and exactly one clock all over.
Very, very strange coding style in those lines of the "process(memPUSH,
reset)". Where did you find this?
To react to a button the usual way is:
1. sync it in
2. debounce it
3. set an edge detection on it
4. use it
Why don't you use integers for the counters? Then this line would look
much better readable for humans:
if S=59 then
Finally it will be very tricky to display your binary H:M:S values on
e.g. 7 segment displays. Because therfore you will have to spit it up
into h10, h1, m10, m1, s10 and s1. So the most easy way would be to
count each segment for itself like id did it there:
http://www.lothar-miller.de/s9y/archives/88-VHDL-vs.-Verilog-am-Beispiel-einer-Stoppuhr.html
BTW: Pls use the [vhdl] tags to wrap your code
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
