Recording Audio on Sena 30K
Guest #6268111
• ▲ useful
▼ not useful
I want to record the conversations that I and my friends are having with
the Sena 30K intercom communication device intended for motorcyclists.
In the attachment you can see the intercom device. As can be seen, the
device consists of two parts. It has a part that attaches to the helmet
to which the main unit is attached. It is responsible for the
transmission of the sound coming via Bluetooth to the loudspeakers. As
you can see in the picture, there is an external headphone output with a
3.5 mm jack. (In the place of earbud)
My question is: I can record audio from the headphone output to an
external recorder, but when I connect to the headphone jack, the
speakers in the helmet are muted. So I can record the conversation, but
I cannot communicate at the same time. When I last tried in a quiet
environment, I noticed that the sound was not completely muted, but
could be heard very quietly. This made me think there might be a way to
increase the volume.
Is there a way to prevent the speakers from being muted when the
device's 3.5mm jack is connected to an external source? Can I prevent
this with a simple intervention?
In an US SENA forum, someone converted the Aux-In (marked as MP3 port in
the photo) into an Aux-Out socket. That would also be an option if it
cannot be done with too much know-how.
I would be happy if those who have information or ideas on the subject
could respond.
Guest
• ▲ useful
▼ not useful
Can you please post a link to that forum thread? Maybe it's easy to do
but too spread across that thread.
br mf
Guest
• ▲ useful
▼ not useful
Many devices switch off the speakers while a jack is connected to the
earphone plug.
This is done by the earphone jack which has a switch inside (resp. two
switches for left/right speakers) and disconnects then the outgoing
signal to the speakers.
Maybe you have the possibility to short this switch by a peace of wire
so that it is always on. You need to be able to open your SENA device
and find out the route of the signal from the amp to the speakers.
I think, the speaker signal is routed from the power amp to this plug
and than further to the speakers. Connect these wires.
You should check before, which wires have a connection when the jack is
out and if they are open, if the jack is plugged in. (Resistor
measurement)
Use for this test a dummy plug and ideally disconnect the speakers to
avoid wrong measurements.
Maybe the setup is different in your device, but I do not have more
informations about it - it's only my suggestion. Perhaps a photo of the
jack environment can help.
So, it is also possible that a controller gets only a logic signal when
the plug is pulled in and it switches off the amp or the connection to
the speakers. Then you need to modify this logical signal.
To amplify the weak signal for the speakers needs much more work.
Guest
• ▲ useful
▼ not useful
Ömer Y. wrote:
> Any toughts?
Not easy.
Pic 3 shows the earbud connector. As I can see only one side of the plug
and no PCB tracks, so it is hard to say more in a reliable statement.
The 3.5mm jack has normally 3 connectios: left, right and GND.
I can see three pads, but are there also 2 or 3 on the other side?
The switch in pic. 2 is probably a pushbutton; it is not that switch I
meant. This is a part of the earbud connector and breaks two contacts if
a
3.5mm jack is inserted.
Maybe these are the two left pads (and two on the other side) of the
plug and the problem will be solved, if they are shortened. But as I am
not shure about the details of the circuit, this may damage your device.
So I will not advice doing this ...
Start a new thread
