D Flip-Flop VHDL code
Guest #6255818
Greetings!
Untested:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity dff is port(
  nCLR : in std_logic;
  nPR : in std_logic;
  D : in std_logic;
  CP : in std_logic;
  Q : out std_logic;
  nQ : out std_logic);
end entity dff;
architecture behav of dff is
begin
process (nCLR, nPR, CP) begin
  if nCLR = '0' then
    Q <= '0';
    nQ <= '1';
  elsif nPR = '0' then
    Q <= '1';
    nQ <= '0';
  elsif rising_edge(CP) then
    Q <= D;
    nQ <= not D;
  end if;
end process;
30
31
32
33
end architecture behav;
Guest #6255933
Hi, all.
Not completely correct, unfortunately. The description above has an
asynchnonous(!) set and reset, and is also missing a clock enable.
process (clk) begin
  if rising_edge(clk) then
    if (set = '1') then
      Q  <= '1';
    elsif (clear = '1') then
      Q  <= '0';
    elsif (clk_en = '1') then
      Q  <= D;
    end if;
  end if;
end process;
Cheers
Moderator (Company: Titel) #6256009
Josh wrote:
> Can anybody help me with D-Flip Flop with synchronous set and reset and
> clock enable?
That is nearby the most simple exercise after "assign an output to an
input". You should get the trick on that before going on...
> I was trying write this code, but actually i can't
Show what you have and tell us what problems you encounter. Then we
can help you.
Otherwise we can continue posting several solutions and you will not be
able to check out which one ist ok.
ktorkkelson wrote:
> The description above has an asynchnonous(!) set and reset
Getting a synchronous description for sure can be achived this way:
library IEEE;
entity dff is port(
  R   : in std_logic;
  S   : in std_logic;
  CE  : in std_logic;
  CLK : in std_logic;
  D   : in std_logic;
  Q   : out std_logic);
end entity dff;
begin
  process begin
    wait until rising_edge(CLK);
    if    R = '1' then -- reset has priority over set
      Q <= '0';
    elsif S = '1' then
      Q <= '1';
    elsif CE = '1' then
      Q <= D;
    end if;
  end process;
(Company: Home) #6299550
Josh wrote:
> Hi!
> clock enable? I was trying write this code, but actually i can't
I think it's may be :
entity dff is port(
  nPR      : in std_logic;
  D        : in std_logic;
  ClockIn  : in std_logic;
  ClockEn  : in std_logic;
  Q_Out    : out std_logic;
  nQ_Out   : out std_logic);
end entity dff;
signal Q,nQ : std_logic;
begin
  Q_Out   <= Q;
  nQ_Out   <= nQ;
 DFF_Process:
process (ClockIn)
 variable SetReset : std_logic_vector(1 downto 0);
begin
SetReset(0) := nCLR;
SetReset(1) := nPR;
 if(ClockIn'event and ClockIn = '1') then
30
  case SetReset is
31
   when "00" =>        -- No operation
32
     Q <= Q;
33
    nQ <= nQ;
34
   when "01"  =>        -- nPR active
35
     Q <= '1';
36
    nQ <= '0';
37
   when "10"  =>        -- nCLR active
38
    Q  <= '0';
39
    nQ <= '1';
40
   when others =>
41
    if(ClockEn = '1') then
42
     Q  <= D;
43
     nQ <= not D;
44
    else
45
     Q  <= Q;
46
     nQ <= nQ;
47
    end if;
48
  end case;
49
 end if;
50
end process  DFF_Process;
51
52
Moderator (Company: Titel) #6300099
> nPR      : in std_logic;
That means for me that CLEAR and PRESET are active, when they are '0'.
So the "forbidden" input combination is "00". But in your incredible
spaciuos written code that is the only combination where the input are
stored.
But in your code "00" is the "normal" state, in which the data input is
stored in the flipflop with each clock.
And also usually CLEAR and PRESET are inputs for an asynchronous
flipflop. Synchronous flipflops have SET and RESET inputs (but beware:
RS-Flipflops also have SET and RESET, but no clock)
Usually a synchronous flipflop with SET and RESET has a priotity on
those two inputs: the RESET input his the most important. When RESET is
active, then its not relevant what level the SET and D inputs have.
(Company: Home) #6300121
Lothar M. wrote:
>> nPR      : in std_logic;
> stored.
  State "00" is wrong state .
 Designer must lock and prevent this state.
 In design we can't leave this state not defined.
 FlipFlop always have state '0' or '1'.
 In my design : if designer not prevented wrong input state "00" , Flip
Flop
 save it last state and do not save/received input state.
 Regards Alex.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
