I am not able to convert MATLAB code to VHDL
OP #6253431
i am trying to convert Matlab code.Thanks it I can finde peaks in a
signal. On the other hand, in VHDL We have an input each clk_period, but
a can discard one in two if it was necessary. I am not able to see or
use this code in VHDL. If I use a FSM I think that it takes longer to
cycle through all states than it does for a new sample to arrive and
restart the process. Can anyone help me? Thanks a lot!!
Moderator (Company: Titel) #6253738
Abel B. wrote:
> I am not able to see or use this code
What does that code do?
If you don't know that you must analyze it.
> If I use a FSM I think that it takes longer to cycle through all states
> than it does for a new sample to arrive and restart the process.
As far as I see you will not need a FSM in hardware. Because there you
don't get the data readily in an array, but instead one after each other
as a continuous stream.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
