Battery supply for microcontroller CC2652R1
OP #6246606
I have programmed the microcontroller CC2652R1 using a development
board. Now I want to produce my own PCB board with a battery as power
supply.
The Manual of the µ-Controller says that it has a supply voltage range
of 1.8-3.8V. Now I am not sure what volage is realy needed. In the
manual there is no hint in what case I need what valtage.
I was thinking of using a rechargable 3.7V battery. Do I have to use a
voltage regulater to convert the voltage to e.g. 3.3V as it was done in
the development board? Or can I use the battery as it is, because its
3.7V are still in the range of 1.8 and 3.8V?
Is it better to have a low or a high supply voltage regarding a
low-power application?  Would it be advisable to just use battery with
less voltage (e.g. 1.8V)
I will be happy about any suggestions.
Thanks
Guest #6247090
The datasheet of CC2652R1 gives clear information in table 5.3
"Recommended Operating Conditions". It runs fine with 1,8 - 3,8 Volt.
Lower voltage brings lower energy consumption. Don't forget that the
nominal voltage of a battery depends on the technology and charge state.
Two 1,5 V alcaline cells have 1,8 - 3,2 V.
A reachargeable Lithium cell has 3 - 4,3 V, which is too much, so that
requires a voltage regulator.
OP #6247189
Thanks a lot.
So to what voltage should I regulate it down?
Guest #6247559
VV V. schrieb:
> Thanks a lot.
Something between 1,8 and 3,8 Volt - obviously.
I assume that there is more than this single microcontroller, so you
should check the requirements of the other parts as well. In case of
doubt, use 3 Volt. Because that's a common standard within the allowed
range.
Be careful with the selection of the voltage regulator. This device has
an RF interface, which usually means that all they consume short peaks
of much more current than written in the datasheet. You need a voltage
regulator that can follow these peaks quickly enough. Also you possibly
want to reduce the standby consumption to a minimum. Only some few
voltage regulators support both together.
The HT7830 is one of them.
OP #6248315
Thanks a lot for your explainations.
Not really. I am using the Controller to get sensor data. So I don't
have any other parts in my circuit till now.
> You need a voltage
What is the aspect in the datasheet which tells me, that it can follow
quickly enough?
During sending, my device consumes 11mA and usually an average of 2mA.
Guest #6248397
> quickly enough?
You wont find that in the datasheet. You need to make your own
measurements in the target circuit. Some chip manufacturers provide
separate documents that tell you how to design PCP and power supplies
properly.
Guest #6248525
> You 11 mA are surely
> also an average value which does cover these peaks.
I did measurments and this is the maximum current it reaches. See the
attached image. Average value 2mA, peak 11mA.
The specification in the datasheet says it takes 9.6mA when
transmitting.
I only have these measurments and I thought I could trust them.
So what qould you recommend?
Guest #6248576
I assume that you did not measure properly. The peaks are so short that
you cannot even see their waveform. You need to measure them with a much
shorter time base.
Guest #6249121
I saw in the datasheet that the RF output power of that chip is only 5
dBm which is about 3.2 mW. This is far less than I assumed, so your
measurement might be Ok.
Anyway you still need a voltage regulator that can handle the peaks
quickly enough, or the voltage would become unstable. Many Low-Drop
regulators are slow, keep that in mind.
As I wrote, the HT7833 can be used.
Start a new thread
