Faster microcontroller
OP #6190604
Hello all, I'm currently using an Mega 2560 PRO (RobotDyn) to read the
UART communication between my ebikes display and controller. It's
purpose is to read specific commands and manipulate them (ex. limit
current draw) or to trigger actions (ex. braking > brake light on).
The momentary speed is transferred using UART as well. Since it's
processing a lot of commands, there's a noticeable delay with speed
updates in the display.
Is there a faster microcontroller than the ATmega2560 to solve this? I'm
embedding it into a 3D printed case. I thought about the STM32H7
(https://www.aliexpress.com/item/4000065515487.html). I'm not into
PCB-designing, so it should be an development board, similar to the
RobotDyn.
I attached an image of my box.
More about this project (in case you're interested):
https://endless-sphere.com/forums/viewtopic.php?t=94850
Guest
Up to Teensy 4.0 with 400MHz.
But probably your ATmega256 is fast enough if programmed efficiently.
Guest
Let me just guess:
You are using several slow uarts with the arduino framework in blocking
mode and now you need a faster microcontroller?
For your task everything with enough hardware uarts should be suitable,
the problem is that some programming skills are required as it was
already mentioned above.
You have two options:
1. Learn to use a microcontroller without a kid-friendly but clumsy
framework (or at least google for a better implementation of the uart,
that would already fix your problem)
2. Ask how to use a raspberry pi for your application, because of your
demand on huge processing power (to keep up with modern arduino makers)
Guest
Kim N. wrote:
> Since it's
Maybe, on over 1000 different commands the parsing speed may have
influence.
But I think, there are other time gulping tasks on your program, e.g.
slow display speed, which can not be solved by a faster CPU.
A typical programmers fault was, that the display was written dozen
times faster, than a human was able to read.
Which speed use the UART?
Guest
Kim N. wrote:
> Have a look into my code
Of course this is slow, because you have programmed it slowley.
All the serial.print slow down the program to the rate of the serial
port, even a digitalRead does take 400 times as long as a
PORTD|=(1<<BITPOS) .
Your program will not run faster if using a faster processor, it must be
decoupled from slow I/O.
First remove ll the unneccessary serial. commands.
Then remove all the blocking while loops.
Simply told: Learn programming. Learn what's behind.
Start a new thread
